Some more 1x9 set u...
[Closed] Some more 1x9 set up questions...
[#1240818]
Hi,
Having had a look through this thread again yesterday I'm now convinced that I'm gonna give the 1x9 set up a go.
http://www.singletrackworld.com/forum/topic/1x9-set-up-would-this-stop-the-chain-jumping-from-the-middle-ring
Emailed bonesetter yesterday and he is running a 29t front ring. Given my riding style I think this would work for me but I have some questions:
1. If I run a 29T front ring and an 11-34 cassette can I run a short cage rear mech?
2. If I can't get on with it would I be able to switch back to a double set up on the front (22t & 32t) and still run the short cage rear mech?
3. Will I be able to get a 29t front ring that will fit an XT crankset or do I need to switch to a Middleburn like Bonesetter is running?
Thanks in advance
Posted : 20/01/2010 12:20 pm
You could probably "make" a short cage mech work over that range, but it might struggle a bit.
See above. I reckon a medium cage and a chain device/fixed front mech would probably work better.
I think XT cranksets are a standard BCD, so you should be able to find an after market chainring to fit. (Blackspires, TA, Middleburn)
Posted : 20/01/2010 12:25 pm
Why not just give the 1x9 setup a go without buying odd sized front chainrings and huge cassettes? Just use what you have now (32/32 I assume)
If you struggle up hills or spin out on the flat then change it. I run 32 fron 28 rear with a road mech and its fine apart from on really steep rocky climbs.
Posted : 20/01/2010 12:35 pm
I would go for a medium cage (GS) mech. It will provide enough tension, look neater than a long cage, definitely provide enough clearance for a 11-34, and be more useful if you change your mind or want to sell on.
Posted : 20/01/2010 12:37 pm
 GW
you'll spin out a 29 tooth ring pretty easily
36 with your cassette choice should get you up anything that's faster to ride up than walk.
won't a 29t need fitting in the inner position and will **** up your chainline.
if you mean short cage mtb mech, yes it'll work with 11-34 and 22/29/33/36
Posted : 20/01/2010 12:44 pm
Thanks for all the feedback, it's much appreciated. You throw up stuff that would never even enter my head so your feedback is invalueable.
I have to strip another bike this weekend so was gonna put those bits on for a start. I'm building it up for a couple of solos this year which although rideable in just the middle ring will prob need lower after 15 hours...
Will a 29t need fitting in the inner position & if so how do you get round this screwing up the chainline?
Posted : 20/01/2010 12:59 pm
29t will only fit in the middle ring (or outer) position on a 5 arm compact drive spider. 32 is the smallest you can go on 4 arm.
Posted : 20/01/2010 1:03 pm
Don't know about the chainline, but you could always run a 32 front with a 12-34 rear if you wanted to lower the ratios a bit?
Posted : 20/01/2010 1:04 pm
i run a 1x9 on my 29er
32t and 11-34 - use a super short Sram x.9 mech - works fine and it should just work with a double at the front, though you need to work out the capacity of the mech and get your chain length spot on.
you might struggle to get a 29t ring for the xtr cranks...
Posted : 20/01/2010 1:10 pm
 GW
sorry, assumed the OPs chainset would be from one of the most recent decades. 😳
Posted : 20/01/2010 1:11 pm
Thanks again for the info. The crankset I will be transferring initially is an XT one, so I would need one with a 5 arm compact drive spider. Hmmmm. That's an expense I was hoping to avoid so will give it a go with a 32 + 11-34 set up firstly to see how I go.
Thanks everyone 🙂
Posted : 20/01/2010 1:24 pm
you could use a shimnao 12-36 cassette if you are looking for a lower gear
Posted : 20/01/2010 1:25 pm
If I was to do that (12=36), would I be OK with a medium cage rear mech?
Posted : 20/01/2010 2:59 pm
32t with a 32-11 (or whatever it is) rear cassette works well for me 🙂
Posted : 20/01/2010 3:04 pm
I would go for a 11/34 cassttee and either a 32 or 36 front ring depending on your local hlls and prefered cadence.
I have run 1x9 11/34 casettee and both 32 and 36 rings. with the 32 you spin out at a fairly low speed around 25mph so if you have much road work or like to turn the pedals slowly this might be too low - but does give a decent low gear for hill climbing. Using a 36 obviously increase the speed at which you spin out but you do loose the lowest gear.
Posted : 20/01/2010 3:09 pm
For me, 32 and 11-32.
I have a fast cadence, and I don't try too hard on roads when i'm on my MTB because I have a road bike for that.
Posted : 20/01/2010 3:14 pm
are you on 26" wheels?
then 32 and 11-34 will be fine.
as a note cage length is related to the total difference between gears inc changes at the front - if you look on shim techdocs or sram tech docs if gives maxium sprocket size and capacities for derailluers
Posted : 20/01/2010 3:26 pm
Will definitely try a 32t + 11-34 set up before dropping any cash on it as I can steal those off another bike. I just know I split my riding time pretty evenly between granny / middle normally and want to lose as little of the lower gearing as possible.
Bike is a 29er. Believe that will make a small difference, a bit more resistance.
Posted : 20/01/2010 3:41 pm
I'm not exactly fit & hardly ever use the granny on my 32/22 double set-up. Eg: Nant-y-Arian, have never used the granny while riding there, or my usual Cannock Chase. You'll get fed-up spinning out at what will seem like a pretty low speed with a 29-34. Guess its down to personal preference, but I'd rather feel a bit of resistance than sitting spinning a high cadence. Probably cos I'm lazy. 🙂
Posted : 20/01/2010 3:57 pm
