Recon solo air - 80kg, what pressure should i be running? 100 (as suggested on the leg) is waaaay too hard
Posted : 05/02/2010 8:36 pm
whatever pressure you need to get the sag you want
Ignore the pressure charts. IME they are approx 20% too high.
Posted : 05/02/2010 8:38 pm
so 80psi (ish) should be ok 🙂
Whatever gives you 25 - 30% sag. Set by experiment. Add a bit if it bottoms out
Posted : 05/02/2010 8:40 pm
pressure req'd depends on lots of variables, frame angles, your position on the bike...
so saying the guide is 20% high is irrelevant, too many variables to consider
Just use the pressure you need to get the sag you want.
Posted : 05/02/2010 8:41 pm
As i said, IME.... 8)
Posted : 06/02/2010 8:46 pm
