So that was two hou...
[Closed] So that was two hours wasted!
5 Users
Hi chaps,
I had a rather annoying squeak from my 5spot, so decided to regrease all ports, which didn't fix it, so ended upstripping the frame down and replacing all the pivot bushes and a new pivot shaft, after lots of experimentation.
Still the squeak stayed.
After a bit more experimentation i discovered it was a still bushing on the top of the sodding shock.
FML.
Posted : 05/07/2013 9:14 pm
You haven't missed anything on the telly..............
Posted : 05/07/2013 9:17 pm
I spent a good hour looking for a replacement hose barb that I bought for my Reverb the other day. When I finally found it, hiding inside a folded up delivery note at the bottom of a box, it turned out that I'd bought one for the wrong end of the hose. 😐
Posted : 05/07/2013 9:23 pm
 kilo
Spent 30 minutes on Thursday tightening up the headset on my prophet to get rid of a post-PPdeS knock before noticing the front calliper was loose and knocking 😳
Posted : 05/07/2013 9:47 pm
could be worse........you could've gone to the cinema to watch 'world war z'! 😀
Posted : 05/07/2013 10:11 pm
