Snapped spoke. Ridi...
[Closed] Snapped spoke. Riding tomorrow!
[#4693011]
Inspected bike and found a snapped spoke on rear wheel. Bugger! Going riding tomorrow.
Is it ok to leave ?
Advice please. Ta.
Posted : 29/12/2012 10:28 pm
I'd not ride it like that , will only get bent and could end your ride with a walk
Posted : 29/12/2012 10:29 pm
I wouldn't ride it either, but I'm a fat knacker.
IME 1 snapped spoke usually results in a load more snapping in quick succession if you don't get it sorted.
Posted : 29/12/2012 10:30 pm
Unscrew the snapped spoke and get rid of it & you'll be fine especially if its an xc or normal trail ride. Would give any big hucks a miss
Posted : 29/12/2012 10:32 pm
Sure. Less crash-bang and more flow and you'll be fine. Worst case is you have to push which arguably you might end up doing every time you head out (assuming you're not in Torridon or similar).
Posted : 29/12/2012 10:34 pm
Should be sound. Depends a bit what rim is it?
Posted : 29/12/2012 10:42 pm
 Chew
One spoke missing is fine for a normal ride. Just remove. Is the rim still true?
Posted : 29/12/2012 10:47 pm
How many spokes, how sturdy is the wheel? I finished the Dudes of Hazzard enduro with 4 broken spokes in a lightweight 28-spoke wheelset, that didn't go so well... But with a sturdier wheelset, it's less likely to snowball, as you've got more margin for error.
Can make it harder to straighten the wheel afterwards though.
Posted : 29/12/2012 10:57 pm
It'll be fine.
Ridden with a spoke taped to another for over a week before now without any issues. Didn't want to miss out on a few rides in the Peak on what was the only dry days of the year.
Posted : 29/12/2012 10:59 pm
I've ridden for months with broken spokes.
Posted : 29/12/2012 11:02 pm
One snapped is fine. Two snapped is time to stop.
Posted : 29/12/2012 11:12 pm
check the tension of the rest...
Posted : 29/12/2012 11:15 pm
I snapped a spoke half way through a biking holiday on an ultra light AC Hub / Stans Podium Rim. Was absolutely fine for the rest of the week and it took a serious battering. Just replaced it and re-trued when I got back home.
Posted : 29/12/2012 11:52 pm
I draw the line at 4 generally more on the 36 hole wheel set
Posted : 29/12/2012 11:55 pm
Thanks for the input. I've borrowed a mates wheel as my rim is slightly buckled.
Gonna play it safe! Going to Bedgebury in morning and didn't want to end up pushing it round!
Posted : 29/12/2012 11:56 pm
andrewni - Member
This. Lots of sensible advice from people called Andrew tonight.
Assuming you have a disc brake of course...
Posted : 30/12/2012 12:03 am
matty456 - Member
I'd happily ride Bedgebury with a single snapped spoke (other than the freeride bit).
If you're there why not get Quench to sort it while you get ready/drink tea.
Posted : 30/12/2012 12:08 am
It will be fine with just one missing, you won't even notice. Just remove it to prevent it fouling as already advised.
Posted : 30/12/2012 9:30 am
I did 175km at Bristol Bike Fest once with only 31 spokes in the rear wheel.
Posted : 30/12/2012 9:59 am
