Snapped front mech ...
[Closed] Snapped front mech on epic evo ๐Ÿ™ help please
GAH, my Sram X7 2 speed front mech has snapped. The lower pivot bolt on the new epic came loose and when tightened it must of bent the bracket. Design fault!? or could of bent when I came off on the last ride...
On the Spesh site it says I have the SRAM X.7, 10-speed, S3 direct mount for DMD, bottom pull
s3 dmd mount is a little confusing!!
would these do?
http://www.chainreactioncycles.com/M...?ModelID=55241 X0
or
http://www.chainreactioncycles.com/M...?ModelID=55246 X9 - I don't believe the picture matches up with the description.
None of the UK web sites seem to show "S3 (DM), Bottom Pull, 26/39t (2x10)" I think its a specific mech. Any help as to where I can get one by tomorrow.
Posted : 16/12/2010 9:25 am
guessing it's too late for tomorrow! what specialized call a DMD mech, is actually a e-type with the bracket un-bolted. if you do a search on mtbr you'll find pictures / descriptions etc. You should find most/all mechs in this configuration
Posted : 17/12/2010 12:27 pm
