Smelly Gore Softshe...
[Closed] Smelly Gore Softshell
17 Users
I have a Gore Phantom that currently stinks in the arm pit region, even when freshly washed.
Any advice on getting rid of the smell without damaging the fabric?
Posted : 03/01/2013 4:26 pm
your name maybe a clue 😉
Posted : 03/01/2013 4:27 pm
Douse with cheap gin.
Posted : 03/01/2013 4:29 pm
Halo sports wash then wash with whatever you normally use
Posted : 03/01/2013 4:37 pm
Oscillate Wildly - Member
Wondered how long it'd take!
I am actually pretty slim, so not that.
Posted : 03/01/2013 4:38 pm
 Bez
Maybe he was saying that you ought to be able to fathom it out, what with being a fathomer.
Anyway. I've got two Gore Phantoms and neither have smelly pits, if that helps eliminate one of the variables 🙂
Febreze?
Posted : 03/01/2013 5:04 pm
Mine did this, albeit when cleaned it would smell fine, but after 1 ride the funk of my worst arm pit smells would return.
Helly Hansen fabric use to be called Smelly Hansen by my LBS due to it having similar properties.
I cleaned mine then sold it to solve the problem.
I now use an Endura jacket, which whilst not as good does not smell so wins in my book.
Sorry to have no actual factual explanation for the Gore-smelly-arm-pit-syndrome. I suspect I used fabric conditioner when cleaning my Gore jacket which Gore says not to use, suspect something happened as a result.
Posted : 03/01/2013 5:08 pm
You haven't mentioned what you used to wash it? I assume it needs a special detergent for the waterproofing? I found with some of my Jackets if I use the Nikwak liquid that everybody recommends they still came out a bit smelly, but the Granger's technical wash is a lot better.
Posted : 03/01/2013 5:33 pm
+1 for Halo Sports wash, I was all my riding kit in it now, no smells anymore
Bez - Member
Didn't get that!
Anyway, thanks for all the responses. I've washed it using Tesco's non-bio liquid and dissolved soap flakes, didn't make much difference. I'll give the Halo stuff ago.
Posted : 03/01/2013 9:58 pm
Vanish Antibacterial should sort it.
Posted : 03/01/2013 10:37 pm
Anyone seen the halo stuff apart from at Amazon where it is £4 delivery ?
Posted : 03/01/2013 11:09 pm
Wiggle sell it, Tesco also have it in from time to time (although annoyingly not for a few weeks in my local store as mine's about to run out).
Posted : 04/01/2013 8:06 am
Had this explained by the Nikwax/Paramo rep a few weeks back. Something to do with wicking. Solution(s) - read care instructions to help make a choice. Dry clean then reproof. Or biowash, pure soap wash,then re proof. Thermals which after a while get stinky - bio, then Nikwax basewash. Had some sample of basewash - seems to work. (If you do the nikwax competition the prize is a sample of basewash iirc)
Posted : 04/01/2013 8:16 am
Douse or spray the pit area in white vinegar, then was as normal
Go to www.dripak.co.uk and follow tips link for more info
I had the same problem with my Phantom N2S jackets
Posted : 04/01/2013 8:24 am
Wiggle sell it,
- thanks, just ordered some
My local Tesco always has Halo in big bottles
Posted : 04/01/2013 11:52 am
 Rio
Sainsburys sell it. Tesco used to do it but seem to have stopped; I emailed the manufacturer to ask why but didn't get a response (maybe I should have asked Tesco).
Posted : 04/01/2013 12:02 pm
 DM52
Halo emailed a news letter about this, basically Tesco produced their own product as competition and pressured Halo into either committing to more promotions / money off or face their product being removed from the shelves.
Posted : 04/01/2013 12:35 pm
Ah that explains why it's not been in my local Tesco for a while, can't say I noticed a Tesco-own equivalent, I guess it's this though? http://www.tesco.com/groceries/Product/Details/?id=275281619
Might check it out as can't read the detail from the pic
Also worth getting Halo sachets if you go away on biking holidays, works great when hand-washing clothes if you need to.
Posted : 04/01/2013 1:00 pm
I use the Assos ActiveWear Cleanser (or something). It's excellent, although probably no better than the Halo one. Not hugely expensive, sorted out a couple of stinky base layers I had.
Posted : 04/01/2013 1:17 pm
Well I ordered some Halo from Wiggle last night, so we'll see how it goes next week.
Posted : 04/01/2013 1:26 pm
An occasional and good soak in bi-carbonate of soda does the trick on my smelly running/riding gear, although it does make the reflective bits go a bit funny. Usually followed by a hot wash.
This gets the whiff out of even the smelliest of hellys, wouldn't use it on anything that might need reproofing though (not sure why, just paranoid).
Posted : 04/01/2013 2:13 pm
