SLX chainsets, 660 ...
[Closed] SLX chainsets, 660 and 665: different cranks?
5 Users
the shimano blurb specifically says that the 665 crank is ...stronger than xt
that implies that it differs from the 660 crank
anyone know if that's actually true? (665 is the double/bash version)
Posted : 21/01/2009 10:16 am
oooh, I've just RTFM. They have different part numbers and aren't interchangeable
suppose they're identical, then ;¬)
Posted : 21/01/2009 10:37 am
Hasn't the 665 got steel pedal inserts
Posted : 21/01/2009 10:53 am
not that clear anywhere but, yes, steel thread inserts get a mention (not on either spec sheet though - unless I just missed it while skimming)
665 is quite a bit heavier despite plastic bashring, so maybe a "bigger" axle too ?
Posted : 21/01/2009 10:57 am
The triple has steel inserts too, well mine has anyway
Posted : 21/01/2009 10:58 am
RTFM?
Posted : 21/01/2009 11:10 am
show me the FM and where the information is within it, and it'd be my pleasure
or are you just bullshitting here ?
Posted : 21/01/2009 11:12 am
RTFM = Read The ****ing Manual jimmy.
I will go find a 660 and 665 in a while and compare them then report back.
Posted : 21/01/2009 11:16 am
oh, soz Jimmy !
LOL
Posted : 21/01/2009 11:17 am
I have the two chainsets in front of me now. The 660 arm does not have a steel pedal insert where as the 665 does along with a washer between the arm and pedal. The opposite end appears to be the same size so should be interchangable if you wanted to.
Posted : 21/01/2009 11:25 am
thanks MrP
yeh, I think "interchangeable" on shimano's site means identical
(do the axles look the same on both ? - surely pedal inserts can't cause 100g weight difference)
Posted : 21/01/2009 11:29 am
