slot drop on one in...
[Closed] slot drop on one inbred brake set up
Just putting together my back-up bike for solo @ Mountain Mayhem and am having a mare trying to get the rear brake set-up.
So I have a got a 2nd gen [url= http://www.on-one.co.uk/i/q/FROO26INSLT2NDGEN/on-one-inbred-26er-slot-dropout-frame-2nd-gen ]slot drop out inbred[/url] and am trying to fit shimano lx brakes and it is just not happening.
So any tips or obvious things I am doing wrong?
(all help very greatly appreciated)
Posted : 15/06/2011 9:06 pm
do you mean they physically will not fit (becasue the mount is on the chainstay) or it's the setup that's the problem.
Elaborate please.
Posted : 15/06/2011 9:09 pm
They fit, or rather seem as they should.
But the mount puts the caliper too close to the top of the disc and this rubs on the caliper.
I am guessing it may well be user error
Posted : 15/06/2011 9:17 pm
ah, also trying to set up with 160mm disc - cheers
Posted : 15/06/2011 9:21 pm
Are you sure it is the correct mount? For instance a 160 mm mount for the front is a 140 mm for the rear. A mistake I made once in a bit of a silly moment so I know it can be done. ๐Ÿ™‚
If this is the case you may just need to find a different mount.
Posted : 15/06/2011 9:23 pm
NB: I'm talking ISO mount here.
Posted : 15/06/2011 9:25 pm
Thanks, pretty sure it is the right mount as has come straight off another bike.
Looking at 160mm IS mount. Bugger!
Posted : 15/06/2011 9:28 pm
shim it out with some washers?
APF
Posted : 15/06/2011 9:29 pm
Another stupid suggestion but I guess you have also tried moving the calliper forward in the slots and the wheel back in trackend?
Posted : 15/06/2011 9:36 pm
Might be the only option, though a little concerned that on end of the caliper does not seem to get anywhere near being attached
Posted : 15/06/2011 9:37 pm
Super front of caliper shimming seems to have got it working, hopefully there is enough of a pad/rotor interface for effective braking.
Cheers for the help guys
Posted : 15/06/2011 11:03 pm
Cakerider... give us a ring here at On-One hq on 01709 386666 if you have any more difficulties- we know of similar problems and can definitely help ๐Ÿ™‚
Posted : 16/06/2011 8:35 am
jon - shimming the front of the caliper seemed to lift it enough so the rotor runs freely.
cheers
Posted : 16/06/2011 9:36 am
