Slipping post
[Closed] Slipping post
[#5110599]
Had the 1st proper ride on my spec camber (carbon). i noticed the post was slipping down slowly whilst riding. i tightened the clamp and it sort of fixed it. im not happy with it TBH, there seems to be quite a bit of slack between the post and frame. im going to measure it tomorrow with my verniers and bore gauge.
any one had the same issues? any ideas?
Posted : 28/04/2013 9:41 pm
did you use carbon paste?
Posted : 28/04/2013 9:48 pm
Used to happen all the time on my stumpy when I had it new. It hasn't happened since I changed the seat clamp to a hope. I don't think the standard spec one was up to much.
Posted : 28/04/2013 9:52 pm
Need another couple of rides to completely confirm it, but my slipping (ali) post has been fixed with carbon assembly paste.
Posted : 28/04/2013 9:57 pm
why would i use carbon paste? its a full bike i didnt build it. should it be supplied with it?
ill look into a hope clamp.
cheers
Posted : 28/04/2013 11:11 pm
well, its over sized by 1.3mm! is this ok/in tolerance? I could put a 31.6 post in it?
Posted : 29/04/2013 5:18 pm
[i]is this ok/in tolerance?[/i]
no.
what size should it be and what size is it?
what size is the seatpost (measured)?
1.3mm is huge though, the post should be waving around, not just slipping.
Posted : 29/04/2013 5:23 pm
it was supplied from new with a 30.9 post when i unclamp the collar it is is 32.2 if you look at the slits in the frame to take up the slack and clamp the post there is a visible gap. i will try to get some snaps tomorrow.
shaun
Posted : 29/04/2013 5:34 pm
