Slackish 120-130mm ...
[Closed] Slackish 120-130mm trail bike?
Other than Whyte, who makes a slackish (say 67-68 degree head angle) trail bike, less than 140mm travel?
just wondering.
Posted : 02/09/2011 10:33 am
 oink
Transition bandit http://www.transitionbikes.com/Bikes_Bandit.cfm
Posted : 02/09/2011 10:36 am
Transition bandit is 68 - http://www.transitionbikes.com/Bikes_Bandit.cfm
/p>
SC Nickel is the same - http://www.santacruzbikes.com/nickel/#geo.php
Posted : 02/09/2011 10:37 am
Santa Cruz TRC
Posted : 02/09/2011 10:39 am
2012 Scott Spark 120mm with a 68 or 68.7 degree head angle.
Posted : 02/09/2011 10:41 am
MBR have a preview of the 2012 Fuel EX and apparently that's getting a 1 degree slacker head angle over the current one. From 68 - 67 degrees I think.
Posted : 02/09/2011 10:44 am
New Ragley 100/140 sounds like it will be slack and low.
Posted : 02/09/2011 10:47 am
As above, those new Treks look absolutely lovely!
Posted : 02/09/2011 10:48 am
Hmm... Yes. Those new Treks and Scotts look just the ticket.
Posted : 02/09/2011 11:07 am
Chumba xcl
Yeti ASR 5 is 68degree with a 120mm Fork
Posted : 02/09/2011 11:18 am
I really like this;
Posted : 02/09/2011 1:48 pm
Yep Yeti ASR-5 all the way, I run mine with 140mm Talas so even more of a slack head angle.
Posted : 02/09/2011 1:52 pm
orange 5 runs great at 120
Posted : 02/09/2011 2:28 pm
Something reasonably short, with a Works Components angle reducer stuck in it?
Posted : 02/09/2011 2:36 pm
 5lab
i've got a mythic (banshee) wildcard. Fits your requirements perfectly (adjustable angles 67 or 68 deg), has a 1.5 headset so you could run a angleset if you wanted. they're a grand at freeborn
Posted : 02/09/2011 2:51 pm
The two Yeti's in dickie's post, are they the same frame, but different sizes? They look very different around the seat-tube/ back end of the toptube...
Posted : 02/09/2011 3:24 pm
On MTBR both are listed as small but the top one is carbon front triangle.
Posted : 02/09/2011 3:34 pm
Hmm... hadn't noticed that before - really like the clean look of the top one, I guess I'd get stiffed with the extra tube if I bought the large.
Edit - you're right, had a look on the yeti site, it's the difference between the Carbon & Alloy frames.
That ASRc is my ultimate "don't need it but would love to have it" bike. Aside from the ones I already have that I don't need.
Posted : 02/09/2011 3:41 pm
Transition Bandit is 67.5deg if you run a 150mm fork. That's what I've gone for and love how it handles. Couldn't be happier with it.
If you want even slacker, the Mythic/Banshee Spitfire is 66deg in the slack setting and only has 120mm rear travel. A bit heavier, though, and there have been some posts on here about issues with bushing wear. Shame, as by all accounts it's a ripper.
Posted : 02/09/2011 3:45 pm
Yep, mine too - halfway between the 100mm & 140mm full susser's I have & lighter than both.
Posted : 02/09/2011 4:07 pm
