Skinny seatpost siz...
[Closed] Skinny seatpost sizes? 25.4mm? Old Raleigh Content.
Bought an old Raleigh Pioneer Jaguar from the tip last year for £10, it had a stuck seatpost and it lived in the garden for a year until I finally got round to buying some Plusgas. Have spent the odd evening over the past two weeks applying Plusgas, and hammering/bashing the seatpost about until finally it started to twist, just done my hands and back in with a set of mole grips twisting it out a couple of mm at a time. As long as I haven't bent the frame whilst levering it about, the only damage is a dent in the top tube after I got a bit over enthusiastic trying to break the corrosion by hammering the post down a few mm!
Anyway, seatpost is 26mm and slides in fine for the first 10cm, then stops. The frame seems to be externally butted at this point, o/s diameter reduces from 29.5mm to 29mm. Assuming it reduces the same amount internally, it looks like I need a 25.4mm post. That seems to be a standard size looking on Google, but are there other sizes like 25.6mm that it could be?
Thanks 🙂
Posted : 01/03/2009 7:12 pm
If you used a 25.4mm post then surely you'll never be able to clamp it? Just use a shorter 26mm post.
Posted : 01/03/2009 7:13 pm
Don't know...I was assuming the clamp would be designed to take up the extra 0.5mm...can't see them designing a bike that you could only have 10cm of post in the frame? I'll have to buy a new one anyway as the old one has huge gouges out of it and the bonded in seatclamp broke off 🙂
Posted : 01/03/2009 7:15 pm
Why on earth would you need more than 100mm of post in the frame?
Posted : 01/03/2009 7:17 pm
100mm isn't exactly much? I'll cut down a post if required but surely it must have come with a 280mm post or so when it was new? I don't know about these things but just as its a roadie bike doesn't mean it was designed for a really short post does it?
Posted : 01/03/2009 7:20 pm
Doesn't give much scope for adjustment if my girlfriend wants to ride it occasionally.
Posted : 01/03/2009 7:21 pm
Old roadie posts were pretty short with not much sticking out above the frame.
Posted : 01/03/2009 7:24 pm
So its meant to have a short 26mm post. Thanks...had better start browsing the classifieds 🙂
Posted : 01/03/2009 7:35 pm
Any other views? Thanks 🙂
Posted : 02/03/2009 7:52 am
Anyone else? Don't want to buy a 26mm post and chop it short if the bike will take a 25.4mm perfectly happily!
Posted : 02/03/2009 9:59 pm
