Singular Peregrine ...
[Closed] Singular Peregrine bottom bracket spindle size
6 Users
Hey all, I working on getting my peregrine build going, but I'm having a little trouble getting a crankset to fit without the chainstay hitting the chainring.
What kind of bottom bracket and crank set are you guys using? -Thanks
Posted : 27/09/2012 11:08 pm
I'm using a Shimano 105 triple, which was fine, now just running the middle ring for an Alfine on the same cranks/bb
Posted : 28/09/2012 4:10 am
Old LX triple, square taper BB, 48T singlespeed chainring in middle ring position. there's 3 or 4mm (?) clearance to the chainstay.
If you're using external BB, have you got the right amount of spacers in the right place?
And it's a bit of an unsatisfactory fudge, but you can always slide the Woods EBB thinger through to the chainset side by a mm, if that's all you need.
Posted : 28/09/2012 7:18 am
I think it need something with MTB spacing - I tried a Alfine groupset chainset, which is road spacing but the 45t chainring on the Alfine (50mm?) chainline hit the chainstays.
It currently works with a FSA MTB chainset and 45t ring in the big chainring position. I can't take any helpful photos as I'm moving house and it's not here.
Hopefully Singular Sam will be along soon to help 🙂
Posted : 28/09/2012 7:21 am
Thanks for the help guys! just pulled some cranks and a bb from another bike i had lying around and they work.
For anyone looking for a spindle size in the future I'm using a 68x125mm bb with an eighth inch single speed 48t chainring and i have good 7mm space between the chainring/crank and the chainstay.
Ride safe!
Posted : 29/09/2012 2:49 am
 OCB
Just for completeness, I use an SLX triple in mine, with a standard HTII BB. I've got an earlier version with the straight stays.
The only slight tweak is that I got a better chainline using two spacers on the non-drive side / one on the drive side tho' (it's normally the other way around).
Posted : 29/09/2012 8:45 am
 Sam
There are two tyres of Peregrine stays, early ones were straight and pretty much only take a mtn crank, newer ones with curved stays will take most compact doubles. There are a lot of variables including chainline, q-factor and number of rings. Drop me a line if you are still having issues.
Posted : 01/10/2012 8:00 am
