singlespeed rear wh...
[Closed] singlespeed rear wheel recommendations
[#1855258]
I'm doing up an old steel racer to become my singlespeed commuter.
Can anyone recommend me a rear wheel. Needs to be 130mm spaced, take a screw-on freehub, have an easily servicible hub and have track bolts.
Thanks in advance.
PS. any recommendations of where to buy very tight jeans also appreciated.
Posted : 02/08/2010 4:59 pm
I should add it needs to be 700c and take a 23/25c tyre.
Posted : 02/08/2010 5:01 pm
Do you mean freewheel rather than freehub?
I have the Surly one, which seems quite good. Cartridge bearings can easily be replaced.
Posted : 02/08/2010 5:07 pm
Yep, I meant freewheel (I'm new to the lingo too!)
Posted : 02/08/2010 5:10 pm
Why? Freewheels are unreliable. Just get a standard wheel and a conversion kit. Much better, especially for a commuter.
Halo wheels are good value and come in loads of colours.
I've used freewheels on my mtb and road bike and not had any problems.
Posted : 02/08/2010 8:03 pm
 Del
no they're not, if you buy the right ones.
i go along with that though. if you don't already have a ss wheel set there's not really that much to be gained from going that way. you're just swapping one bearing for another, and i believe the dishing benefits negligible.
Posted : 02/08/2010 9:49 pm
 Haze
I've had the Halo ones for about 7 months now, no problems so far.
Posted : 02/08/2010 9:52 pm
Thanks all. Think I'll go for a standard wheel with a kit.
Posted : 03/08/2010 9:21 am
Del - which are the right ones? I heard that the WI ones are reliable but seeing them in use they don't actually seem to be.
Posted : 03/08/2010 11:01 am
 D0NK
I've used shimano ones, seem OK. Serviceable(ish) if you wish or cheap enough to chuck and get a new one. Quite fancy a WI one tho.
Posted : 03/08/2010 12:03 pm
Are you sure it's 130mm ?
A lot of old steel road frames were 126mm - FYI
Posted : 03/08/2010 1:03 pm
nixon_fiend
It had a (very knackered) Quando rear hub spaced to 130mm in it. It takes a little prising apart to fit a standard 130mm axle in there.
I'm trying to find out a little more about the frame (age, make etc.,) from the previous owner so that should help me.
Posted : 03/08/2010 1:25 pm
