Single Speed Ratios...
[Closed] Single Speed Ratios for a 29er!
[#2626771]
What are other people using on their S/S 29ers?
Posted : 03/04/2011 6:43 pm
it makes no difference, they're only for show not actually riding you know 😀
Posted : 03/04/2011 6:44 pm
32:18 for general use - Mendips, Quantocks.
Posted : 03/04/2011 6:46 pm
follow the words of wisdom of my favorite beardy SS racers Fuzzy and dejay and use a 33-18 to 33-21 with a rotor ring depending on the course.
Or a Neddy Overend and use a 34 rotor ring with a 21 rear.
Posted : 03/04/2011 6:49 pm
32:18 on Mt Malvern. Although sometimes I wish it was 18:32
Posted : 03/04/2011 6:50 pm
32:19 in scotchland, 32:17 in england (MASSIVE GENERALISATION ALERT)
will be 32:20 in the alps.
Posted : 03/04/2011 6:52 pm
Interesting! I rode 25miles today over rock, bridals and some tarmac using only the same gear on my 27 gear Scandal! 32 middle at the front and the forth one up at the rear, 17 I think? It felt OKish and maybe an eighteen could be right! A 19 sprocket which I have purchased could be too easy?
Posted : 03/04/2011 6:57 pm
32:18 on a 29er is the same as a 32:16 on a 26er so I guess these are the standards but it depends on what sort of peddler you are......
Posted : 03/04/2011 7:14 pm
32:18 in the summer/dry, 32:20 in the winter/slop, much better for the old knees
Posted : 03/04/2011 7:26 pm
Cheers all!
Posted : 03/04/2011 7:38 pm
What's a "bridal" is it a fair where you buy wedding dresses?
Posted : 03/04/2011 7:41 pm
Might be a stuipd question but how do you use a rotor ring on a ss, i am assuming you need a sprung rear tensioner?
Posted : 03/04/2011 7:46 pm
Sorri! Nat a scool a te momont!
Bridle! 😛
Posted : 03/04/2011 7:50 pm
ssboggy - works fine with a pukka ss, none of this tensioner cack. You set the tension the cranks at a 4-5 O'clock position which puts the highest tension on the chain, the slighter slacker spot on chainring doesn't cause any issues. I've had the chain skip off once and that was due to a sliding drop out/chaintug issue. 😀
Posted : 03/04/2011 8:01 pm
/quote
Bridle!
/quote
could somebody translate that please?
Posted : 03/04/2011 8:06 pm
Been experimenting with ratios using what I already had and what came with second hand wheels and cranks I've bought.
34x20, 3.7m felt a bit low.
32x18, 3.8m also felt a bit low.
34x18, 4.1m was definitely too high.
I've gone back to 32x18 for now. It's a bit spinny at times, but I'm doing longer rides now the weather's warmer, so I can put up with that if it makes the climbs easier.
I'll stick with it until the sprockets wear out, then I'll probably give 34x19, 3.9m a go.
Posted : 03/04/2011 8:20 pm
 mjp
32 / 20. Around Otley, Baildon and it still hurts!
Looking at evryone elses gearing I must be bloody unfit!
Matthew.
Posted : 03/04/2011 8:21 pm
Posted : 03/04/2011 8:30 pm
Anyone use 38:16?
Posted : 03/04/2011 9:48 pm
Only on the cx!!
Posted : 03/04/2011 10:00 pm
So is 36:18 the same as 38:16?
Posted : 03/04/2011 10:22 pm
Put the numbers in here.
http://sheldonbrown.com/gears/
It's a lot easier to understand ratios when everything is converted to a single number.
The Metres Development is only to one decimal place, or 100mm though.
The Gear Inches is more accurate, at .1" or 2.54mm, so better for calculating slight differences.
Posted : 03/04/2011 10:33 pm
32:19 gets me up pretty much anything 'round my part of the Chilterns (except that flippin Stonor climb). Spinny on the flat bits though...good job there's aren't many of those 🙂
Posted : 03/04/2011 10:39 pm
Just the one ss ratio does for me 🙂
Posted : 03/04/2011 10:46 pm
32:18 around Cannock Chase (not the Monkey/FtD bit). Think it was in 32:20 when I did the Monkey Trail on it, & it felt ok but stupidlt spinny elsewhere. I was running two at the rear & swapped to suit. Just put a dedicated ss rear wheel on so now its stuck at 32:18.
Posted : 03/04/2011 10:47 pm
32:20 South Downs area Brighton.Seems to be good but does spin oout on the flat....I like my knees though :oD
Posted : 03/04/2011 10:48 pm
32:19 in the South Pennines, 36:20 on the Pugsley
Posted : 04/04/2011 5:29 pm
 Sam
34-19 here most of the time
Posted : 04/04/2011 5:34 pm
32:18 on the borrowed TD-1 was fine for 12 hours at Hit The North and for 100 miles at Kielder.
Posted : 04/04/2011 6:11 pm
mike - you have mail regarding the freakybeast proto
Posted : 04/04/2011 6:42 pm
 Keef
34/19 mostly.
33/20 day out rides,where there may be gearie mates(so's not to embarass 'em toooooo much 😉 )
Posted : 04/04/2011 6:53 pm
surely for riding a single speed 29er all you need is the gear of "mince"
Posted : 04/04/2011 6:55 pm
YGM back 🙂
Posted : 04/04/2011 6:57 pm
 Keef
Tazz,who gave you permision to use that photo of me ?.........
Posted : 04/04/2011 7:00 pm
keef, it's from my shrine in homage to you, All stuck to the wall with "the special stuff"
EDIT: are those jones H bars in the pic?
Posted : 04/04/2011 7:09 pm
 Keef
Tazz, you knows it ,'big boy' :mrgreen:
Posted : 04/04/2011 7:39 pm
