Single speed compat...
[Closed] Single speed compatibility questions, for a Scott Frame. Please help.
Hi,
Ok so I really want this crank Octane One [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=70089 ]'3-PCS Cro-Mo Crankset 2012'[/url] but the crank arm is straight, and my old one bent out slightly. So I'm really worried that I'll buy a crank that wont fit, cause it'll get caught on the drive side chain stray, on my frame.
Any response welcome,thanks!
Posted : 16/04/2012 2:21 am
It says chain line perfect for mtb, suggesting it will work on a mtb, ie clear the stays also.
You can just buy it and then send it back if not.
I have to ask...why?
Posted : 16/04/2012 6:23 am
kk thanks man, yeah it says 'fits all 68mm BB MTBs' so if it don;t fit back it goes.
Why what? 🙂
Why singlespeed?
Posted : 16/04/2012 1:06 pm
Why those cranks. Al has single speeded for years so he knows an answer to that one. Unless, that is, he's been pulling the wool and is really just a wannabe fashionista and has no idea at all why he SS's.
Posted : 16/04/2012 1:20 pm
why those cranks? emmm i dont know :s
firstly they are pretty $_$
and i cant fit a 29t ring on my current crank, if there are better cranks, please tell me 🙂 for around £70-£80
Posted : 16/04/2012 1:25 pm
They look heavy. I presume your bike is light?
Posted : 17/04/2012 12:43 pm
They look heavy.
1.1kg with the BB! that's half a lb more than most tripple chainsets! And why do you need a 29t?
Posted : 17/04/2012 12:53 pm
my bike aint that light, its octagon tubing aluminum scott voltage, 1.1kg, quite weighty i suppose but the buy button has been pushed :s
still it might not fit, crank arm might hit the chain strays.
i do have a second single speed crank w/ 36t ring but i really wanna run a 29t/12t, with the smallest rings.
so what crank should i have gotten that'll fit a 29t ring? : (
Cheers!
Posted : 17/04/2012 3:22 pm
why 29-12?
No benefit I can see to going non-standard, are 29T rings common, and 12T may jump sooner when worn?
Posted : 17/04/2012 3:27 pm
28 is more common i believe, not 100% on that. the main benefit is you get the same ratio as larger chain rings, but in a smaller package. i think thats how it works, sorry, im so outta my depth, just looking to get my head above water and understand dis stuff : )
although i just thought, a crank isnt a bad place/thing to be weighty is it? bottom of bike and solid materials. THanks : )
Posted : 17/04/2012 3:31 pm
Is the voltage that jump bike thing? If so steel 3 piece cranks'll look fine. Even if they do collapse under their own gravity 😉
yar it is, it like an 05 though, to be honest, its probs rubbish but its top tube is parallel to the seat strays, and i love that design style.
i'll upload a pic of it, excuse the state its in atm! : )
Posted : 17/04/2012 3:34 pm
heres the frame it's going on
and here is the amount for clearance, on my current crank, not sure the octane one will fit now that i look @ it again.
Posted : 17/04/2012 6:30 pm
