Show me your me you...
[Closed] Show me your me your unobtrusive roof bike rack.
We will soon get a Cmax and I'm looking at the best way to carry a muddy bike or one with full mudguards. This rules out going inside. Currently use a tow bar which means having the rack and light bar clogging up the boot.
Some roof systems have bars ,then a bit bolted on that ,then another bit bolted on that. Mrs Zip would not approve.
So going with the system pictured and just need a lockable don't know it's there bike rack. Needs to take one bike ,a 26 or a 29.
Posted : 24/09/2015 9:34 am
Think you've basically found your answer, but for one bike I'd go Thule wingbar edge with 591 bike rack.
Posted : 24/09/2015 10:02 am
There's no such thing as a don't know it's there bike rack, they all run perpendicular to the bars so it's obvious.
The Thule stuff is all silver so if you have a dark coloured car it's even more obvious
Saying that, I really rate the Thule stuff
Posted : 24/09/2015 11:39 am
Thule wing bars here, not very unobtrusive though...
[img] ?oh=9025bdb93103a9bfa366906e5a4aa65b&oe=569D14C0[/img]
Posted : 24/09/2015 11:42 am
seasucker?
Posted : 24/09/2015 11:43 am
My roof bars (Thule) are all black, it's only the bike racks themselves that are silver. So if you take the carriers off it's black bars and feet on a black car, which is OK.
If the OP is trying to avoid roof bars, that need mounting to the roof, and then a way of holding on a bike it will mean you need bars going across and then a bike carrier at 90 deg to those bars. There is no real way of hiding the fact you have a bike on a roof, as you have well a bike on your roof.
Why would the missus not approve, is it looks or hassle? Putting bikes on my roof takes about 10 mins, 2 bars, 4 bolts, lock in place, slide the carriers on, mount bikes and go. Just remove when you are home. Takes up the same space in the garage as the bike rack
Posted : 24/09/2015 11:53 am
Strap your Missus to the roof, bike in the car. Job done.
Posted : 24/09/2015 11:54 am
They're all fairly noticeable but I think the combo of a set of Whispbars (that fit between the rails) and a Thule 561 (mounts front hub to rack) is probably as close as you're going to get both in terms of looks and noise.
I use this above (plus a wheel bag for the front wheel) and originally planned to remove them when not in use... they've never come off the car. Only thing worth noting is if you've a sun roof you may have clearance issues with the low profile bars.
The 591 is a bit less of a faff as you don't have to remove the front wheel but IMO not as secure or as neat a solution as the 561.
Posted : 24/09/2015 1:02 pm
Thule wingbars here too attached to Volvos roof blades, bit of a stretch getting the bike on the roof of my XC60 but only do it occasionally. I have to open the rear doors, lift bike onto rack, strap wheels in, let go!!!! then lift up the securing bar and clamp the downtube..
Never done this in a breeze and I'm not looking forward to the first day I have to either. ๐Ÿ™„
Normally the bikes in the car, I mean thats the point of an "estate" innit, but occasionally I have a couple of folks in there too, hence the rack.
Posted : 24/09/2015 2:05 pm
