show me your lightweights
You're gonna have to define that.
Some folk will say 30lb is light, others only sub 22lb etc.
Also, there was a thread on this recently. Use the search.
[img] http://images.fotopic.net/?iid=11c2bt&outx=800&quality=70 [/img]
Oo oo, pick me, pick me! This is 21lbs dead with Rocket Rons, a SID fork and some ti-axled Egg Beaters. Currently got a Furious Fred on the back, not hung it on the scales in that guise though, should be about 20.7lbs.
This is quite lightweight. Not sure how lightweight, but it can't be more than 25lbs.
[url= http://farm5.static.flickr.com/4045/4541957162_a126a8e0d8.jp g" target="_blank">http://farm5.static.flickr.com/4045/4541957162_a126a8e0d8.jp g"/> [/img][/url]
njee20 - It would weigh even less without the cable reel hung on the front. 🙂
Oh dear forgotmename, you actually call it your 'baby' too!
Rip - that is a stunner!
Why the 4-pot brakes?
And it has no pedals, so you actually took it to a muddy pond purely to take a photo of it, good effort 🙂
183mm M4 on an arse-heaven fork?
Wait for it..
Waaait for it...
Snap!
That was rather what I was thinking!
You should stick an XTR chainset on that, that'll drop a chunk 🙂
Funny that I've got just the one! Unfortunately it's adorning the 456Ti got any more?
Is that a 2003 Epic steve? Those early ones were weighty buggers!
Not right now! Although it's not beyond the realms of possibility at some point in the future!
Still think those scales may need a check Steve, those early Epics were weighty buggers
I suspect they're in the ballpark, based on the weights for my other bikes (23ish for my Zion, 27 for my Soul and 30+ for my Enduro when it had Talas and an RP2 - haven't weighed it since fitting a coil shock and Pikes though as I reckon the scale would explode). The Epic has different wheels (American Classics) now as well, and they're quite a bit lighter than the HopeXC/717's that used to be on it.
I've never weighed just the frame of the Epic but it doesn't seem all that heavy.
Bugger, edited too slowly, I thought it was closer to stock spec, I agree that sub-25 is right with the SID on there!
They got a lot lighter in their early years, IIRC the stock 'Comp' v-brake model in 2003 was about 28lbs, no wonder they weren't that popular!
Mine was actually the base model 2003 one, not even the Comp and I suspect it'd also have been 28lbs or so.
It's very non-stock now though - SID teams, American Classic wheels, XTR drivetrain and brakes, Litespeed Ti railed saddle, carbon seatpost and bars, Speed King supersonics (and Twister Supersonics for summer). Other than the frame and fork I think the only other stock bit left is the LX front mech as it just refuses to die and I won't replace it until it does!
My S-Works Epic frame (Large 2006) is 2650g....(or 680g more than my Spark)
Not so porky if you ask me.
From an completely non scientific "heft" test I'd say that my Epic frame and shock doesn't feel much heavier than my Inbred frame (although that does give a good impression as being made of lead).
BTW brake force is proportional to how hard you pull on the bars, not how big your rotors are or how many calipers you have. HTH.
Surf-Mat - MemberRip - that is a stunner!
Thanks!
njee20 - MemberWhy the 4-pot brakes?
The build was finished and the pedals hadn't arrived! Couldn't wait to get a photo though.
I have the four pots on all my bikes just to keep spares inventory down really.
Apart from changing to Middleburn cranks it's just the same now. I have the Scale version too and hardly ever ride the Spark. I'd probably sell it to someone who'd appreciate it.
I strongly suspect that most people only have one calliper, although there were some very dodgy twin calliper forks around in the late 90s!
Aside from that, are you actually saying that you can exert the same braking force with a 160mm XC race brake as you can with a 203mm Hope Mono 6 ti?
Aye, they got lighter by then, the seat tube/top tube bridge was hollowed out significantly, Brain Lite shock, hollow magnesium mounting, carbon linkage etc etc, the 2003 ones really were heavy, heavier than the Stumpjumpers of the same era.
Of course the bigger brakes have a higher maximum force, but when you're slowing down do you:
a) Pull the brakes on as hard as they'll go.
b) Apply as only as much power as required.
If you choose option b) then you'll squeeze the levers with a bit less force and exert the same force on the forks, when compared with less powerful brakes. Not a problem.
I can see how option a) would pose a threat to some forks, but if that's your choice, your forks are the least of your worries.
But surely it's a value judgement, you brake based on what you know your brakes are capable of. If you have bigger, more powerful brakes, you will brake harder and later purely because you can, ergo exerting a greater force on the forks.
Is there not an issue with the actual amount of leverage on the bottom of the fork legs too, hence maximum rotor sizes on forks.
26.5lb.......waiting for the abuse
really I got the pretty similar setup and mines 29lbs?
If you are posting bike weights then post the size of the frame as well.
It avoids unnecessary willy waving.
The Top Fuel is 18.5"
KINGTUT - No offence does that make a huge difference with lightweight frames?
No, it doesn't. It's rarely more than 0.25lbs between identical bikes with a medium and large frame. There's often more variation in identical bikes in the same size frankly!
I guess the difference between a 13" and a 22" is probably >1lb though.
Between a 14" and a 20" yes I would say so, but as njee says not so much between a medium and a large, but it's still a measurable difference.
But heck why let facts get in the way of a weight weenie willy waving thread. 😉
njee, yep its my xc baby. and its my light full susser, not my heavy 1.
It's not a heavy bike, it simply appears very heavy for what it is, which I stand by. But that's an altogether different argument!
KINGTUT - MemberIf you are posting bike weights then post the size of the frame as well.
I've got an extra large - and no i've never had any complaints
I'm sure I could get it a lot lighter by borrowing scales from some other posters on this thread.
If that's aimed at me, may I point out all the bits where mine's lighter? 😉
No i know that bike isnt that heavy really, but i do have another bike that IS my heavy one,making the 1 in the link my light full susser, sorry for the way it was written. Heavy bike on that link somewhere.
And its not an argument, i respect your thoughts njee.
Oh that Blur is lovely. I've been lusting after one of those so badly lately. That build looks spot on as well.
I think Foes should also be applauded for very much going against the grain, with a short travel XC biased bike that's not all about the weight!
delusional - Member
Ta. Photo was taken this afternoon at GT - first time I've been out on it this year 😳
I was trying out a slightly shorter stem and it was just perfect. Hmm - shorter stems [i]are[/i] lighter, right?
I'll have to get a photo of my Helius up this weekend, been on a bit of weight loss recently and is now just over 26.5lbs, not bad for a 129mm travel Easton 7005 frame in Large 🙂
It could be lighter if I went silly with XTR but ain't got the cash, or the inclination 😆
XTR isn't silly in weight saving terms surely, it's positively conservative!
I reckon going beyond XTR to save a few grammes is where the transition is made from being normal to being a weight weenie.
I think to 99.9% of people, XTR is quite "silly."
Mine. 24lbs with XT- I saved weight on the wheels, frame and forks. It'd be easy to get it down nearer Njee weight with carbon seatpost, a lighter stem and XTR. I could lose more by going for things like light QRs and crank brothers pedals but there are some points where weight saving isn't a good thing.
It's meant to be my race bike, but I find I'm racing little and trail riding lots lately and am tempted to take the hit and fit 120mm forks.
How is that Tall Boy lighter than than Druid's Blur XC Carbon? Are they the ZTR Race 29er wheels?
njee20, maybe the sum of a lot of little things; the tubeless Pythons are v light (but a bit shite at the mo') 4ti pedals, Masterpiece post, carbonio Flite, KMC X9sl chain, Marta SL's, grips (cut down), XO rear mech and rotary shifters, dunno what bars he's running, but might be a bit there (?) ditto cassette, Maxm stem - silly light. So there might be a pound there, mind you all irrelevant now, put on Rampage 2.35's last night! Worth it though in our present conditions.
Possibly. The Pythons are about 680g though, the Blur XC appears to have 2.25 (at a guess) Nics, which are 580g, not to mention the frame difference...
njee are you quoting tyre weights from memory?
A Bit late....Large Scott Spark 20.8lbs including pedals bottle cage and garmin mount....
http://www.flickr.com/photos/10738091@N07/4548196113/in/photostream/
[img] http://www.flickr.com/photos/10738091@nN07/4548196113/in/photostream [/img]
[url= http://weightweenies.starbike.com/listings/components.php?type=usttyres ]Look here.[/url]
some nice bikes see if we can get some under 20lb
Nice to see some New Ultimate kit Moda! I had a seatpost for the Fuel, but now I don't distribute it I sold it! Still think their kit is spot on.
How's the KCNC cassette too?
I'd like to get the Fuel under 20, but it's not gonna happen without some new wheels, and money on the bike just isn't a priority at the moment!
22.7lbs
in the blue corner @ 25.5lb (calibrated digital scales)
[url= http://farm5.static.flickr.com/4067/4584540102_63142ceffb.jp g" target="_blank">http://farm5.static.flickr.com/4067/4584540102_63142ceffb.jp g"/> [/img][/url]
in the silver corner @ 27.5lbs (calibrated digital scales)
[url= http://farm4.static.flickr.com/3257/3107360626_c26c3b9f21.jp g" target="_blank">http://farm4.static.flickr.com/3257/3107360626_c26c3b9f21.jp g"/> [/img][/url]
Both 18" frames.
My upgraded Anthem X4 (only the frame and forks are left 😳 )
XT groupset, Next SL bars, ZTR Olympic wheelset run tubeless etc
Since this pic the pedals were changed for Candy 2ti running on Ward Industries titanium axles - 190g pair
Not sure what the weight is guessing somewhere around 24-25lbs
