Show me your DIY no...
[Closed] Show me your DIY no-drill ground anchors
About to move into rented house. I probably shouldn't drill into the garage floor to put in proper ground anchors. Thought I might make a couple of large concrete blocks with something set into them. What have others used, and where did you get the materials, esp the chain or loop?
Posted : 30/03/2015 8:43 pm
builders bucket, some Postcrete and a d-lock
Posted : 30/03/2015 8:45 pm
A big bucket or barrel with chains hanging out, fill with concrete which weighs a ton, hey presto a bike with a very heavy thing attached to it.
Posted : 30/03/2015 8:47 pm
Bald tyre for free from local car mechanics, some concrete inside it. So then you can loop chain for padlock inside it.
Posted : 30/03/2015 8:51 pm
Cool, cheers. Thought about silicone buckets and postcrete....it's just the chain or loop that I was struggling with as I don't really want to write off a u lock or hardened chain. The tyre idea might help though. How do you fill it...in sections?
Posted : 30/03/2015 9:08 pm
Yep, make it up not very wet and I got it done in 3 goes. I used 3 bags of premixed stuff from B&Q for a fairly standard tyre.
Posted : 30/03/2015 9:11 pm
I just drilled a hole in the floor of my (rented) garage to put a ground anchor in. I convinced the landlord that it added value and he didn't mind (as long as it was somewhere near the corner).
Posted : 30/03/2015 11:08 pm
I drilled the garage floor in my last rented house, didn't even consider any other options as i was locking my motor trials bike to it, I also drilled the walls and fitted bike hooks and anchors to the walls to lock those too, when I left I cut them off with the grinder and ground them flat, they were barely noticeable then!
Posted : 31/03/2015 6:52 am
Isn't a U lock much cheaper than buying a proper ground anchor ?
Posted : 31/03/2015 7:29 am
Nope, ground anchors 10 - 15 quid from Screwfix. Decent u-lock 30 plus....
Posted : 31/03/2015 5:55 pm
Have a look in your local Yellow Pages for a "Concrete Reinforcement" supplier - they'll often have a waste skip of offcuts - look for a bent loop of thick rebar that you can set into a concrete-filled 40 litre flexi tub (which will weigh about 80 kg if you fill it to the brim).
Posted : 31/03/2015 6:41 pm
Landlord would probably be happier to see a nice security anchor smartly bolted to his garage floor when you've left than an 80kg block of concrete, plastic and re-bar for him to deal with!
Posted : 31/03/2015 7:04 pm
