We have a garage, but its so full of bikes I need to store them to make better use of floor space.
Bit of a first world problem I know.
What have you guys come up with?
I got some wall mounted bike racks from class olsen, they hold about 2 bikes each so I can get 8 in the garrage (2 racks on each wall) and still get the car in.
Ladder hooks from B&Q or similar cost about £1 each, just hook your front wheel in them, hey presto.
Ive recently bought a pulley system from Lidl, not tried it yet but for a fiver it has to be worth a try...
Hanging bike verically by front wheel by hook is best imo. If horizontal space is an issue, go for two battons at different heights, then alternate the hooks between the two.
My garage is narrow, have shelving and workbench on 1 side, 2 bikes on horizontal racks high on opposite wall, 2 on floor underneath- both locked with anchors.
No pics.... so I'll try to describe.
All mine are wall mounted - I have an asbestos ceiling in my garage, so can't touch it. Total storage area for bikes is one wall approx 12ft(l)x8ft(h). Depth is c.3ft.
I use these for 5 bikes (come in road and MTB flavours). Rear wheel sits on the ground for each bike to take the strain off the wall.. 3 of them are MTBs stored in a space less than 3ft across - just loosen the stem and twist the bars.
[img] https://encrypted-tbn0.google.com/images?q=tbn:ANd9GcRnRVf66nGmu2SYVpmHjREWUaaEKsQ0Oa_n8NDknJi2vdih3Ey6aQ [/img]
And something similar to this for 2 bikes (I have 2 separate racks) from B&Q - these hang the bikes above the vertically stored bikes.
Is it ok to hang your bike by its wheel without damage to the rim?
what kind of damage would you be expecting?
I don't frikkin know, that's why I asked the question 🙂
I dint think hanging them like that was good for suspension forks, especially if they are oil?
I thought it was good for the forks to be upside down, as the oil drains through the fork lubricating etc. If the brake calipers are above the levers then any air in the system will work its way up, causing a drop in braking performance. It sorted itself out for me once they were the correct way up, but a mate of mine had to get his rebled.
My bike is always stored hanging by the front wheel, it did mess the brakes up when there was air in the system so I bled them properly solving the problem and resulting in significantly better brakes...simples 😀 Also as turtlegeading said storing the forks upside down is much better as it lubes the upper bushes and seals.
The only exception to the fork rule is early Rebas and Revelations. Rock Shox had an O ring on the gate dial (the gold knob on top of the blue compression knob) that was a bit feeble, and consequently a little oil used to weep out. Not a big deal, except that the oil cart it was leaking from isn't that big itself, and oddness occurred (according to TF Tuned) if too much was lost. I had three Reba-based forks at the time with the problem, and none of them exhibited aforementioned oddness, although I did end up storing them wheels down.
I currently store four mountain bikes front wheel up in a shed. Nary a problem, but I should say that the nice cheap hooks from Wickes, B&Q and the rest are a little narrow for bigger tyres or rims - I've got a pair of Easton Havocs with 2.25 Advantages on them, and that can be a tight squeeze. It's also easy to knock the rubber coating off the tips of the hooks, so watch you don't end up scoring your rims. That said, a replacement hook is a quid...
I've no shed so bikes have to be stored in the house. I had planned on using [url= http://www.cycloc.com/ ]these[/url] but I need to get 2 bikes on a rack, so I opted for basic Halfords racks.
[IMG]
[/IMG]
