Shout out for Alumi...
[Closed] Shout out for Aluminium.
[#4905915]
All I ever read is how awesome steel is.
I have just sold my On One Inbred frame to build up an Identiti AKA 7005 alloy frame. I'd just like to say how awesome it felt going back to aluminium.
The alloy frame won't oxidise in such a manner as to render it useless. It is stiffer, lighter, stronger and therefore much, much better. Anyone else here feel the same.....?
Posted : 25/02/2013 8:41 pm
And if you rub it hard enough it goes shiny. 😀
Posted : 25/02/2013 8:54 pm
yep, love my Cham, when it breaks I'll buy another. Done all the steel is real stuff. Don't think I'll go back
Posted : 25/02/2013 9:01 pm
one of my bikes is alu, and its great.
2 of my bikes are steel, they are great too.
ridden a ti bike in the 90s, it was, er, er, um, like, ok i suppose.
what about a wooden bike?
i havent ridden one of those.
Posted : 25/02/2013 9:06 pm
Stiffer =/ better. But also alu isn't always stiffer than steel.
I have carbon, alu, ti and steel bikes. They're all good.
Posted : 25/02/2013 9:08 pm
Stiffer is not always better... Got to choose the right material for the job, and then get the design right.
I have a salsa dos Niner alloy 29er, the walls must be super thin as the front triangle flexes like good steel.
An on one inbred is very basic steel, so it's not like you have experienced a great set of steel tubes... And I am sure there are steel frames lighter than the Identiti... But crack,on and enjoy your ride.
Posted : 26/02/2013 10:07 am
...but will fail earlier...
Posted : 26/02/2013 10:09 am
Scienceofficer - Member
Indeed, assuming you are referring to my thin wall salsa.
I dented the frame in the first two miles.
The rear end is a soft tail, IN SCANDIUM, so it's flexing all the time, in the area that will get chain suck gouges...
i am over 15 stone, and I am constantly surprised it has not snapped.
Posted : 26/02/2013 10:16 am
 Joe
boo
Posted : 26/02/2013 10:22 am
Aluminium for full sus
Ti for hardtails
Carbon for racers
Steel for pub bikes and beards 🙂
Posted : 26/02/2013 10:25 am
Hahahaha, I would like to say, for the record I have a titanium frame, a carbon frame and an alloy full suss. I wanted to set a cat amongst the steel biast pigeons to really see what they could come up with. And Charlie- you need to lay of the beer dude.
Posted : 26/02/2013 6:01 pm
it that a fair comparison, going from gas-pipe steel to aluminum?
Posted : 26/02/2013 6:04 pm
Probably not, thats why I sold it.
Posted : 26/02/2013 6:05 pm
Without sounding toooooooo nerdy - Al will oxidise more readily that almost any other metal - even at very low partial pressures of O2 (in a vacuum for instance). However, unlike steel, Al will oxidise using parabolic kinetics rather then linear(ish) kinetics for Fe based alloys (with low Cr content).
Another pointless fact is that Ti (and its alloys) has one of the highest specific strengths (strength against density) of any element/alloy
Right - ill get me coat!
Posted : 26/02/2013 9:03 pm
I like aluminium,all my ladders are made from it .My bikes however are steel
Posted : 26/02/2013 9:05 pm
Not really.
It's a double and triple butted, chromoly tubeset, made by Founderland in Taiwan, rebadged as Reynolds 520 and various other things with other house brand names.
Posted : 26/02/2013 9:07 pm
Touché
Posted : 26/02/2013 9:13 pm
It's interesting that the chromoly 4130 tubing is the same as a reynolds 520 tube set.
I wonder just how much marketing I am un- doing with this post now. 🙂
Must confess I love being able to hose the bike down and not worry about the frame, as its s.s and at the moment rigid I only have a freehub, disc brakes, b.b and headset to worry about.
Posted : 26/02/2013 9:15 pm
[pedant] both the frames you are referring to are made of an alloy [/pedant]
I'm also yet to have a steel alloy frame rust enough to be rendered useless. You hear of the odd frame rotting from the inside out but I think it takes years of abuse.
Posted : 26/02/2013 9:19 pm
ha! please forgive my lapse metallurgist terms.
There has been so much grit on the roads recently I didn't want to find out.
I did like my on one frame however the identiti just offers up much more potential, 650b wheels, sliding drop outs (nothing the inbred didn't) handling up to a 140mm fork, ( I have a lovely talas fork awaiting installation [dependant upon weather conditions] ) just a shame it isn't made- or designed in Yorkshire.
Posted : 26/02/2013 9:28 pm
I also like ally, as my Filing Cabinet is made from it. However my HT is fillet brazed Tange Prestige & it's tubes can be easily replaced, & is now on it's Mk 8 version. It's at the framebuilders having a new top tube & powdercoat, I'll post photo's when I get it built back up again.
Posted : 26/02/2013 9:30 pm
Just in case your tempted- I also have an ally cat....
Posted : 26/02/2013 9:33 pm
