Should I go ghetto ...
[Closed] Should I go ghetto tubeless?
It's been suggested that it might be an ideA. I'm gonna be using dt 4.2 rims and conti vert pros. Any downsides? What sealant?
Posted : 01/04/2009 10:56 am
I used Wheel Milk from Just Riding Along seems to have worked just fine. 3 weeks and counting....
I used new Maxxis Minion/Crossmark on DT E540 rims and had no probs at all.
If you're a habitual tyre swapper then tubeless isn't great. I will change the rear in the Autunm i imagine.
They sealed/seated with just a track pump and have great so far. I really only did for stop thorn punctures as i was getting them almost every ride!!
No weight gain in my case as i the Maxxis were heavier than the Kenda they replaced. If i had kept to Kenda then there would have a very small weight decrease.
I now the tyres at around 30-35 psi, loads of grip and no chance of pinch flats either.
Continental are supposed to be fine for ghetto.
Posted : 01/04/2009 11:59 am
done it on my 719's with crosmmarks for summer. seems fine up to now.
Posted : 01/04/2009 12:00 pm
