Should I build my l...
[Closed] Should I build my long travel hardtail play bike as a "46er"?
Just building up a Woodman D to muck around on - its designed for 26" wheels but when WMB tested it favourbly way back in 2004 they used a 170mm Sherman fork but with a 24" front wheel amd 26" rear to keep front end under control. Thoughts on handling etc?
Posted : 09/07/2009 7:38 pm
I'd have thought it'd better to do it the other way around - 24" rear for quick acceleration and 26" front to roll over stuff better (appreciate that'd be madness with the Shermans though . . . slacktastic ๐Ÿ˜‰ ). I ran a 26"er up front on my little Stinky 2-4 - rocked on the downhills but climbing was definitely not an option.
Having said all that, I'm sure it's something I'd like to give a go to. Love messing around with different set-ups and geometry and the lower front would definitely make the Shermans more manageable on the ups.
Posted : 09/07/2009 7:50 pm
would have thought the angle of attack of a bigger wheel would negate the more travel but smaller wheel.
Posted : 09/07/2009 8:02 pm
24" on the back with a 3" tyre on, it's how I run my .243 and it's a right laugh
Posted : 09/07/2009 8:11 pm
From memory Worland only did that to keep the angles from getting too slack. thomthumb has a point though, so unless you've already got 170/180mm forks and a 24 inch wheel is it really worth it?
Posted : 09/07/2009 9:39 pm
