Should brand new Gu...
[Closed] Should brand new Guide RS need bleeding?
[#9516468]
Because they feel ever so spongy? Put some on my mates lads bike today, with new centreline rotors, and I can pull the levers back to the bar. I've only had Shimano before which are obviously more on/off than most, but even the Levels on my wife's bike feel firmer. I had assumed brand new brakes wouldn't need bleeding, but perhaps that was a wrong assumption?
Posted : 26/08/2017 9:42 pm
Well mine didn't. Send them back.
Posted : 26/08/2017 9:51 pm
The ones on my Anthem did.
Posted : 26/08/2017 9:56 pm
Or....bleed them.It ain't rocket science.
Posted : 26/08/2017 9:57 pm
I'm sure it's not. It'll be particularly hassle free for me since its not my bike and it's gone home to its owner 🙂
Posted : 26/08/2017 9:59 pm
Just one of those things. Some do, some don't. Depends on how well bled they were from the factory - and the assumption is that if you're cutting hoses to fit, you'd bleed post-fitting anyway.
Posted : 26/08/2017 10:19 pm
The guide rs I had first were perfect and didn't need bleeding.
The guide r I have now has a slightly mushy front brake that needs a bleed. If I tried hard I could probably get the lever back to the bar when the bike is stationary. If I tried it whilst riding I'd be over the bars way before I got close.
Posted : 26/08/2017 10:57 pm
I get to see this a lot, and freeing up the pistons, allowing them to come out a little further than normal, then pushing them all the way back, and spending time aligning the caliper correctly (not squeeze the lever , tighten the bolts, and hope it's right) so both pads hit the disc flat, square-on, and at the same time, will result in a much improved lever feel. You may still want to bleed them just to be sure, but unless we've cut hoses, we've not had a new set that needed bleeding yet.
Posted : 27/08/2017 6:50 am
Never bled out of the box and even cut the hose on a Guide with care not to drip anything and no bleed required.
What @coatesy says basically about alignment and pad contact. The RS I think doesn't have bite adjust? so need to manually do it. Method I used to use was squeeze lever couple of times with wheel out, then wheel in. Should be quicker contact.
Calliper alignment though I usually do by (wheel in) slackening bolts, squeeze and hold lever, carefully tighten bolts bit at a time, alternating. Release and hope it spins without catching.
You'll still get a slight squish feel with the Guide levers compared to some other brands. There's more flex in the lever I find.
Posted : 27/08/2017 10:57 am
Cheers, we'll give those things a try.
Posted : 27/08/2017 6:09 pm
 ajaj
We have 4 sets of Guide R (not RS). Three are fine and have never needed bleeding. One has been nothing but trouble and needed bleeding from new and again after a few days.
Posted : 27/08/2017 10:44 pm
