Hi Need the shortest stem for os bar standard steerer mount 1/1/8" no rise if poss. have a 50mm anything shorter available am/trail spec.
Suggestions please
cheers
Diabolus D2 35mm, OS
35mm is the shortest before the bars hit the steerer.
DMR,Kore,Straightline,RF,Pro,Easton(25% off on crc),Answer,Spank do them.
Easton Havoc, 35mm
or a stem from a mondraker
Yep had thought about a Mondraker one, however I think they've got a bit of rise on counter aced by the really short steerer tubes on the FG frames, so it may lift the front too much. The 50 with 5 degree rise is currently flipped to get a bit of drop.
Cheers for the replies few other models I hadn't considered, being a bit tarty on colour schemes on them as need to match the wrap the frame is getting (full custom vinyl) ๐
๐ more pink would be overkill ๐
