Shortening Magura B...
[Closed] Shortening Magura Brake Hose Simple Q
Hi
I've watch the video on shortening the brake hose on my Magura MT Sports but just checking if I can reuse the support sleeve/disc tube insert from the section that is being cut away or do I need to order new ones?
Thanks
Posted : 01/10/2021 8:53 am
The official answer will be always use new but I have reused Magura (and others) so long as they haven’t been damaged.
Posted : 01/10/2021 9:18 am
I've reused those before from several manufacturers. Carefully remove from the cut section to avoid damage (I tend to cut the pipe almost through along its length).
Posted : 01/10/2021 9:21 am
Excellent thanks! I'll trim the length then slice along the length of the trimmed section.
Posted : 01/10/2021 9:22 am
Didn’t you get spares with your brakes??
I bought Magura new and it came with two spare barbs and olives in the box
Posted : 03/10/2021 10:53 am
So did mine. If it came fitted to a complete bike though you may not get those parts.
Posted : 03/10/2021 10:57 am
