Trying to do set up some Pikes but the SW is not playing ball. I knew something was a miss when it told me I had 160 psi in ....
With the shock wiz not attached to anything it is reading between 80 -86 psi. The battery was flat prior to this - I have replaced with quality battery. And when I got these readings I tried another battery.
I have followed the manual’s reboot section. And that makes no difference at all.
Any thoughts?
Thanks
Colin
Something physically sticking/pressing on the valve?
Nope - nothing ..
Both valves have been depressed just in case 86 psi was hiding in the SW body ...
Still under warranty?
I hope so ...
Ours got replaced under warranty, but it stopped connecting to the apt.
86psi could actually be completely correct if you are about 50m below the surface of the sea.
Have you checked if you can breathe unaided? Can you see an unusually large number of fish?
OP is the man from Atlantis and I claim my five pounds.
Replaced under warranty ....
awesome... i'm not sure how long i've owned mine...
Do you know how long the warranty is ?
