Shock wiz calibrati...
[Closed] Shock wiz calibration.
Trying calibrated front pike forks. If I completely empty them of air I cannot extend to full travel...
Any suggestions?
San I run them with 5 psi in, or does that knacker the calibration/?
Posted : 04/11/2019 9:16 pm
Leaving a little bit in gas never been an issue in my practice. Sometimes it can come down to weird little things like that depending on the forks.
Posted : 04/11/2019 9:20 pm
Managed it with about 8 psi in...
Posted : 04/11/2019 9:46 pm
mtfu or is it ptfu nowadays?
Though I remember standing on my the rim of front wheel, while trying to drag the front end up, was a lot of fun on rev's.
PS: I got a ratio of 2.2 IIRC
Posted : 04/11/2019 9:53 pm
2.1 on 130 pikes ....
Posted : 04/11/2019 10:21 pm
2.5 on 150 Pikes
Posted : 06/11/2019 2:38 pm
It would helpful if RS published this information.
Posted : 06/11/2019 2:39 pm
well, ratio also does depend how many spacer you are running, not just length of travel.
Posted : 06/11/2019 3:29 pm
And interestingly RS don't ....
Might also be helpful in Shock Wiz did as well
Obviously, spacers will make a difference ...
Posted : 06/11/2019 3:39 pm
A database would be useful.
2.5 on 150mm Yaris.
2.6 on 160mm Yaris.
Posted : 06/11/2019 4:15 pm
doomanic
Subscriber
2.5 on 150mm Yaris.
2.6 on 160mm Yaris.
Toyota? 😆
Posted : 06/11/2019 5:24 pm
2.2 on Pikes now at 140mm ...
Posted : 20/04/2020 10:42 am
Posted : 20/04/2020 10:49 am
And the version of the air shaft.
2017 Pike, upgraded air shaft, no tokens 4.9 !
Is my Shock Wiz knackered ?
About 50 psi but shockwiz says 9.7 psi 🙁
Posted : 20/04/2020 3:38 pm
Mine has a solid red led and wont connect, any ideas?
Posted : 20/04/2020 3:43 pm
Think I had this on mine and it turned out to be a flat battery.
Posted : 20/04/2020 6:21 pm
Tried about 8 include 4 new ones out the packet.
Posted : 20/04/2020 7:03 pm
TBH - I would send it back to SRAM. They were very keen to replace mine.
That said - I am not too sure how much value it really has ..
Posted : 20/04/2020 8:41 pm
TBH – I would send it back to SRAM. They were very keen to replace mine.
That said – I am not too sure how much value it really has ..
Can you send them direct or does it have to go back to the seller, in this case bike discount?
Posted : 20/04/2020 9:00 pm
Have to go back in to the seller. But I did talk with Shock Wiz / SRAM directly
Posted : 22/07/2020 1:35 pm
what brand of battery are you using? I'm pretty sure they dont play nicely with Energizer or Duracell batteries for some reason - mine works fine with Panasonic batteries, but a brand new Energizer doesnt work at all.
Posted : 22/07/2020 2:33 pm
