shock stroke length...
[Closed] shock stroke length question
[#748398]
If you have a 130mm travel bike fitted with a 200mm i2i shock with a 57mm stroke and you then fitted a 200mm i2i shock with a 50mm stroke, what would be the consequences/results?
Am I right in thinking slightly less travel with slacker angles?
Posted : 30/07/2009 6:02 pm
less travel but same angles
Posted : 30/07/2009 6:04 pm
So the other way round if you went from a 50mm to a 57mm stroke you'd gain travel, the amount being dependant on the stroke/suspension ratio thingy?
Posted : 30/07/2009 6:13 pm
If you went the other way, you would have to make sure your frame could take the extra travel. ie. wheel or seat/chainstays don't clash with another part of your frame through over travel.
Posted : 30/07/2009 6:30 pm
you'd gain travel but the wheel/rocker/links would all be closer to the saddle/frame/other gubbins so you may break stuff
Posted : 30/07/2009 6:31 pm
Cheers folks
Posted : 30/07/2009 6:34 pm
