Shock mounting bolt...
[Closed] Shock mounting bolts
In the process of re-building my Bronson C MK1 and need some new bolts, the ones which run through the rear linkage and hold the shock in place.
Having has a look at the tech sheet they appear to be 22mm x 8mm:
https://www.santacruzbicycles.com/en-GB/bike/bronson/1
Has anyone used a normal allen head bolt before or does it have to be the ones supplied by Jungle?
Posted : 20/06/2017 12:57 pm
I've replaced with standard bolts before. Just get high tensile ones with a grading eg 8.8 or 10.9 rather than cheap unknown ones. Also try to get ones with a partly plain shaft rather than fully threaded although that's less of an issue (and probably impossible) for ones that short
Posted : 20/06/2017 1:00 pm
They're a bit more difficult to get in shops I find, but on the other hand, just contact Jungle and they'll send you some. I snapped one, mentioned it to them, they sent some free bolts.
Posted : 20/06/2017 1:08 pm
Thanks guys. I tried to contact Jungle when I needed some last year but they never replied.
Would this be OK? https://www.amazon.co.uk/Bolt-Base-Tensile-Socket-screws/dp/B00SN34FFW
Posted : 20/06/2017 1:19 pm
Anyone know if the above would work?
Posted : 20/06/2017 4:06 pm
looks like they would to me
I never buy the bolts from the bike shops as they cost pence if you have a shop nearby- I reckon about 10 p per bolt but i would still have to post them to you so not much saving
Luckily I have a specialist nuts and bolts place so they have everything needed - sometimes some obscure italian or american thread options cannot be purchased here
Posted : 20/06/2017 4:09 pm
Looks like the sort of thing.
Out of interest, the spare one I've got from Jungle is marked 'THE A2-70' bolt. A2-70 from what I can tell is a stainless steel grading. Which is great, until you snap one and have to drill it out. Tough going drilling SS ๐Ÿ˜€
Posted : 20/06/2017 4:39 pm
Thanks guys. I might try my local DIY shop tomorrow and if none there order the above.
Posted : 20/06/2017 5:20 pm
