Shimano/Magura brak...
[Closed] Shimano/Magura brake compatibility question
I have centrelock wheels, so can I use Shimano discs with magura calipers - say Louises?
Or can you get centrelock magura discs?
Posted : 08/09/2009 10:09 pm
Centrelock rotors will work fine as long as the dimensions are the same - i.e. 160mm, 180mm, 203mm.
Posted : 08/09/2009 10:38 pm
So I assume there's no difference in thickness (i.e. thicker - thinner and they would be just like worn ones?)
Posted : 08/09/2009 11:00 pm
