Shimano XT HG95 VS ...
[Closed] Shimano XT HG95 VS Wippermann 10S8 10 speed chain? Shimano cassette.
Need a new chain as my old Wippermann 10S8 is close to worn out, got an XT 11-32 cassette, been happy with the Wippermann, but now it's quite noisy (could be the chainring).
Should I try a XT chain instead (designed for the cassette, and with sil-tec) or stick with Wippermann? Concerned about chains snapping, but also want a quiet drivetrain and smooth shifting, where shimano + shimano seems optimal.
I would use the connex link with the shimano chain.
Posted : 24/09/2019 11:42 am
I wouldn't go XT over Wipperman, personally. Not even close.
Posted : 24/09/2019 7:12 pm
Why not?
Posted : 24/09/2019 8:10 pm
Shimano chain every time.
If you've worn out your chain what about your cassette, isn't it recommended the replace both at the same time. I've got an unused wipperman 10SX stainless, still in its packaging, I've also got a barely used XT 771 cassette 11/34 to sell after moving to 11sp. Will stick both on ebay for £45. I've also got a used 10SX with loads of life left in it.
Posted : 24/09/2019 9:30 pm
Cassette looks ok, most replace chains more often than cassette, with the XT 771 i can replace the 4 smallest sprockets which are all I use basically.
I'm in Germany though so not sure it'd be worth it with shipping, keen to try the XT one.
According to this independent test Wipperman is basically the same as Shimano re longevity, but worse value and perhaps shifting
https://zerofrictioncycling.com.au/chaintesting/
Posted : 24/09/2019 10:04 pm
