Shimano WH-M775 whe...
[Closed] Shimano WH-M775 wheelset - bearing service
[#4397312]
I'm servicing the bearings in my Shimano WH-M775 wheelset. The tech document:
[url= http://techdocs.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/WH/EV-WH-M775-R-2769B_v1_m56577569830728616.pdf ]Shimano Tech Doc[/url]
Shows some sort of caged bearing, "item 5: Ball retainer (3/16)"
Can I just replace this with lose 3/16inch ball bearings? Or do I have to get one of the caged bearings?
thanks Jai
Posted : 25/09/2012 10:56 am
anyone?
Posted : 25/09/2012 5:42 pm
can't see any reason why they need to be caged, other than ease of assembly, but you will need a few more bearings to take up the space of the missing cage.
Posted : 25/09/2012 6:51 pm
cool thought so. I assume the same method as headset bearings applies? ie Fill up the cup and take a couple out.
thanks Jai
Posted : 26/09/2012 5:36 pm
Just remember XT uses/requires Grade 25 bearings. Not Grade 100. And certainly not the Grade 1000 rubbish sold at most LBS.
Posted : 26/09/2012 6:06 pm
