Shimano Ultegra 670...
[Closed] Shimano Ultegra 6701 10 Speed Chain with SRAM powerlink?
I'd like to replace the chain on my bike and actually get a couple of new Ultegra chains and swap them every 100 miles or so. I've only ever used SRAM chains in the past so am used to a powerlink, can this be done with such a chain:
Super narrow lightweight 10-speed directional chain for optimum cassette and chainset interaction and maximum power transfer (recommended for use with double systems only).
5.88 mm chain width optimised for 10-speed Super Narrow HG drivetrains
I couldn't see where I can get a powerlink for this?
Posted : 03/12/2012 10:26 am
You can, but the 10 speed SRAM links are Power Locks, not Power Links, they're designed to be single use. You can get them apart with the master-link pliers, but they're not designed to come apart.
KMC Missing Links are replaceable, and will fit fine in a Shimano chain, although I prefer KMC chains. Get X10SLs from Taiwan on eBay and they're generally £22 or so.
Posted : 03/12/2012 10:35 am
I've used a mavic chain as it was only £10 Vs ~£25 for shimano and came witha quick-link, although I'm not convinced it wasn't a false economy as when I swap wheels to the much less well used (summer) pair it skips on 13/12/11 sprockets. I've got a 10s KMC link (cheep for a pair of pairs from decathlon under their own brand) in a DA chain for those wheels now and it's fine even through the chain is supposedly directional (you'd have to be unlucky to shift at precicely the wrong moment and even then I doubt it's noticeable in the real world).
Posted : 03/12/2012 10:48 am
