Shimano mineral oil...
[Closed] Shimano mineral oil in Tektro HyRds?
I know the paperwork says Tektro only or death, but I can't be the only person with a large bottle of the red stuff who's pondered this.
Anyone tried it, or know why it really would result in A&E?
Posted : 11/08/2017 8:29 am
It'll be fine. ๐Ÿ™‚
Posted : 11/08/2017 8:32 am
 cp
Mine are full of Shimano mineral oil. Works a treat.
My tip for bleeding Hy:Rd's... use the epic bleed solutions kit with two syringes. Remove the caliper from the bike and hold the caliper in different orientations whilst bleeding... And rotate it round in you hand whilst bleeding. Loads more air comes out than a static bleed.
They're impressively powerful brakes!
Posted : 11/08/2017 8:34 am
There's only mineral oil or DOT brake fluid used on bikes. If the brakes don't use DOT, you can slap in the Shimano (mineral) stuff and it will work fine.
Posted : 11/08/2017 8:35 am
[url= http://www.epicbleedsolutions.com/blog/dot-brake-fluid-vs-mineral-oil/ ]Probably won't do any harm, but manufacturers don't support it.[/url]
[url= https://www.bikerumor.com/2013/04/11/tech-speak-brake-fluid-break-down-and-implications-for-road-disc-updated/ ]Edit: More info here.[/url]
Posted : 11/08/2017 9:15 am
Cheers for the info ๐Ÿ™‚
Posted : 11/08/2017 9:47 am
You really don't want to switch DOT for mineral or vice-versa as your seals will suffer if you do. e.g. Hope are always DOT4/5.1
For DOT fluid it's important to get the right grade (normally DOT4 or DOT5.1), but don't bother buying the bike-specific stuff. Just get it from your local motor factors.
Mineral oil has more choice, but I'm in the "chuck Shimano in everything" camp as I have a large bucket of it in the garage.
Posted : 11/08/2017 10:16 am
 cp
Where's all this DOT chat come from?? Hy:Rd's are mineral...
Posted : 11/08/2017 10:19 am
Mine have it in them and one of them still works!
Its a sticky rear piston but i doubt the fluid is the cause as it was shit before I bled it
Posted : 11/08/2017 10:27 am
Was being more general with answering the question. You'd be surprised how many people put "brake fluid" into brakes without realising that they're not all the same...
