Hi guys I'm having a serious problem with my xt rear brake lever it's leaking oil out of it, this can be seen on the reach adjust screw also while bleeding there is a continuous amount of air that gets in!
I was wondering if anybody knows if this can be easily fixed or is it a new lever to replace it?
If its not too old, its probably covered under warranty. Check with your LBS. Otherwise probably a new lever assembly including reservoir.
Think it is too old and it's second hand from eBay!!
Thanks for the reply I found exactly where the leak is coming from aswell now, not sure if you will be able to see it properly though!
[img] http://s558.photobucket.com/user/jtaylor2105/media/F8725B7D-E85C-4FF3-918C-30E562F7CFBB.jpg.html ][IMG] http://i558.photobucket.com/albums/ss24/jtaylor2105/F8725B7D-E85C-4FF3-918C-30E562F7CFBB.jp g" target="_blank">http://s558.photobucket.com/user/jtaylor2105/media/F8725B7D-E85C-4FF3-918C-30E562F7CFBB.jpg.html ][IMG] http://i558.photobucket.com/albums/ss24/jtaylor2105/F8725B7D-E85C-4FF3-918C-30E562F7CFBB.jp g"/> [/IMG][/URL][/img]
