Pretty sure my dimensions add up, but just to check in case there's something I'm missing...
I have a Mavic crossride disc hub from around 2006-ish, it has a 2mm spacer and was used with a Shimano 8 speed cassette.
Can I use a 10 speed cassette on this?
Posted : 20/10/2013 9:26 am
yes
Posted : 20/10/2013 9:45 am
Excellent, do I need to change or omit the spacer or anything?
Posted : 20/10/2013 9:52 am
yes - assuming it takes 9 speed whihc is why you need the spacer - not that i have tried with that wheel set
dont use the spacer - you would realise this when it does not fit though!
Posted : 20/10/2013 10:02 am
Cheers, that makes sense and is pretty much what I thought.
Thinking of building some cross wheels, I have either 32 hole rims or 24 hole hubs to base from...
Posted : 20/10/2013 1:14 pm
