Shimano Deore XT FD...
[Closed] Shimano Deore XT FD-M770-E ..any experts?
2 Users
 jeb
I mounted it direct to my specialized camber alu 2013 frame, i routed the shifter cable on the downtube, and under the bottom bracket, and up through the small hole behind the bottom bracket. And i clamp the cable to the anchor there, bit it pulls the wrong way! -the fd should could run both top and bottom, but i cant see how to run it otherwise .. 😥
Posted : 03/09/2013 10:53 am
The cable does'nt go directly to the clamp.It threads up through the middle of the mech over 2 'guides' (2 hooks above the clamp bolt) and back down to the clamp bolt.
Posted : 03/09/2013 11:06 am
 jeb
Oh dear........... yummy i will get asap home and do your trick!
Posted : 03/09/2013 11:21 am
Just make sure the cable lies along the whole guide bit,they have a tendency to come off the side until there's a bit of cable tension (especially if you're moving the mech by hand when setting it up).
Posted : 03/09/2013 11:26 am
 jeb
Rorschach, your the man, it just instant worked, and i got a little bit wiser..., - i was otherwise at the point to a mechanical brain-meltdown 😆
So thanx a lot.
Posted : 03/09/2013 12:58 pm
