shimano crank/pinch...
[Closed] shimano crank/pinch bolts - where to buy?
i have slightly "rounded" one of the crank/pinch bolts today and although its just about ok i probably need to replace it now rather than wait until my next maintenace session where i will surely "round" it completely!
so where can i buy a couple of spares from as i can't see them on wiggle etc (unless of course i am looking in the wrong place!)
thanks
Posted : 25/05/2009 4:25 pm
Stock bolts. Use decent stainless ones if you can but any fastener supplier should have them
Posted : 25/05/2009 4:29 pm
cheers tandem,
do you know what size they are?
are the drive side and non drive side the same sizes?
Posted : 25/05/2009 4:47 pm
M6. They are only on the NDS though?
Posted : 25/05/2009 4:50 pm
M6 x 20mm-ish. They may actually be slightly shorter than that but M6x20 will work.
Posted : 25/05/2009 4:52 pm
If you use ones that are about 5mm longer than the normal ones then you reduce the risk of stripping the threads.
Posted : 25/05/2009 4:55 pm
cheers for that and of course they are only only on the non drive side - doh
Posted : 25/05/2009 4:59 pm
Disc caliper bolts work (at least Shimano ones do).
Posted : 25/05/2009 5:50 pm
