Shimano Crank threa...
[Closed] Shimano Crank thread size?
3 Users
I managed to put in a pedal cross threaded and screwed up the first few threads 😳
I know that it is 9/16" but is it UNC UNF? I'm going to buy a bolt to put in from the other side and re-cut the thread.
Posted : 26/03/2011 6:53 pm
Its 9/16x20, finer than UNF
Posted : 26/03/2011 6:59 pm
 Keef
get an old pedal,cut 3 or 4 slots along the threaded part,(easier with an angle grinder,with a cuting disc)as in,at a right angle to the threads,screw in from rear side of crank arm.
init.
Posted : 26/03/2011 7:01 pm
Cheers for the tips the old pedal axle worked a treat 😀
Posted : 27/03/2011 9:53 am
