Will 10-speed HG94 chains work ok with Campag Xenon components?
No.
9 or 10 speed Xenon?
10-speed. Will it have to be one of these then? http://www.chainreactioncycles.com/Models.aspx?ModelID=57808
[url= http://www.ribblecycles.co.uk/pp/road-track-bike/chains/CHAI ]ribble compatible chains[/url]
Are ribble still doing free postage? If not it's cheaper here
and here
Cheers chaps.
Find a KMC 10 speed road chain - that'll work and will last longer than the bike.
as glutton says KMC every time
A shimano 10 speed chain will work with with Campag so I do not know where the "no" posted comes from. Campag chains work on shimano drive trains as well. You should be able to use 10 speed chain on 9 speed as well.
Give it a go.
A shimano 10 speed chain will work with with Campag so I do not know where the "no" posted comes from. Campag chains work on shimano drive trains as well. You should be able to use 10 speed chain on 9 speed as well. The distance between campag sproket teeth is the same as on shimano sprokets -1/2" it is the one bike thing that is standardised.
Give it a go.
I agree with buy a KMC chain over a shimano chain though. I would also take a KMC chain over a campag veloce chain. Cmapag record on the other hand is a very good chain.
Apparently 10 speed mtb chains and 10 speed road chains are different widths or have plates which are differently profiled.. Not sure that I believe that though.
They're not. a load of bull, maybe Shimano have tweaked there plates a little but I always use Dura Ace chains 10s on but road and MTB and they work equally well for both applications
+1 for what Blazin says. It will work fine - HG94 mounted the correct way of course. Have used Shimano DA chains on my Campag equipped road bikes for years - no problems.
It would work but I wouldn't disgrace my campag with a shitmano chain
But you've already disgraced your bike with campag?
