Shimano brake pad q...
[Closed] Shimano brake pad question
6 Users
Bit confused..
The exploded diagram for my SLX M675 brakes details 4 different types of pads so Im assuming the more recent finned type pads are compatible? Do the finned pads make any difference? seems like a bit of a marketing gimmic to me
Shimano SLX front disc brakes
are the "normal" pads just the non-finned XTR race pads?
Whats the difference between G01S and G03S pads?
Posted : 20/02/2014 10:37 pm
A link or picture of the exploded diagram might help? finned pads apparently help to dissipate heat better but I've not personally noticed any difference, although I do use icetech rotors.
Posted : 21/02/2014 12:36 am
G01 are resin, G03 are sintered, both non-finned. F01 are resin and F03 are sintered, both with fins. Personally I would use the sintered non-finned because I ride wet flat places.
Posted : 21/02/2014 6:31 am
Oh and all brakes from XTR down to Deore use the same pad shape. However the backing material changes. There are steel, aluminium and ti versions of the non-finned. The ones on the SLX diagram that have an S on the end of them are steel. Cheaper but fractionally heavier, if that worries you!
Posted : 21/02/2014 6:43 am
does any one know of any where relatively cheap for the sintered shimano NON finned ones?
Posted : 21/02/2014 8:55 am
Oscillate Wildly - Member
I use Disco Brakes or Uberbike (no fins Sintered) on my SLX M675 and had no problems at all
Posted : 21/02/2014 9:18 am
bigmick my experience is they dont last anywhere near as long as genuine shimanos for me in the peak district
but if i cant get them cheap enough ill buy some uberbike, although they are out of stock at the mo
Posted : 21/02/2014 9:32 am
Superstar Components
Posted : 21/02/2014 9:33 am
[url= http://techdocs.shimano.com/media/techdocs/content/cycle/EV/bikecomponents/BR/EV-BR-M675-R-3286_v1_m56577569830800233.pdf ]The exploded diagram if anyone is interested[/url]
Posted : 21/02/2014 10:00 am
thanks everyone, cleared a few things up! 🙂
Posted : 23/02/2014 8:33 pm
