Do I need the hub setting tool, does the rotor really need removing, and what cone spanners sizes?
I've come across conflicting information by using google...
Thanks,
Tim
Posted : 18/06/2013 12:32 pm
bump
Posted : 18/06/2013 1:26 pm
No you don't need the hub setting tool, but if the cone has become too tight you may need a vice to grip the axle at the other side, otherwise the axle rotates with the cone.
Does the rotor need removing? No.
You need a 28mm cone spanner, and also something larger (32mm if I remember right) for the lockring. I used a big adjustable.
Posted : 18/06/2013 1:33 pm
