Sheared pinch bolt ...
[Closed] Sheared pinch bolt ?
[#4163673]
Help how would i manage to remove one of the m5 pinch bolts on the left side of my xt crank.Some how even using a torque wrench the little bugger managed to shear off and is it easy to get a new bolt.You think your doing the right thing buying the correct tools and still things manage to go wrong oh bugger.
Posted : 15/07/2012 3:20 pm
 GW
sheared at the bolt head, aye? this happened a few years ago to a set of Saints I (still) have, I drilled right through the centre of the bolt then simply wound it out with an old screwdriver jammed into it. replaced with a standard metric bolt o higher quality IIRC
Posted : 15/07/2012 3:26 pm
drill a groove in it so you can unscrew it with a flat screwdriver
or buy a screw extractor drill bit
http://www.screwfix.com/p/screw-extractor-set/18643
either way take care and probably quite hard to dril
Posted : 15/07/2012 3:27 pm
it can go out the other end too (if the bolt is threaded all they way)
replace with decent M6 socket cap as above.
Posted : 15/07/2012 3:31 pm
