Shaving Oil (metros...
[Closed] Shaving Oil (metrosexual content)
I've tried a few shaving oils and apart from an ancient & defunct Body Shop one they all seem to bloat/stick to the stubble which then clogs up the razor.
Can anyon recommend anything?
Posted : 14/07/2009 9:45 am
For your legs or your face? Or is it the bikini line?
Posted : 14/07/2009 9:47 am
King of Shaves - the blue one, works for me.
Castrol R. The only oil you need for close shaves
Posted : 14/07/2009 9:49 am
It's all just GT85 in a diffferent tin, probably.
Posted : 14/07/2009 9:52 am
Yup, King of Shaves blue for me as well. The trick is to run hot water through the blades after shaving to help remove the clog
Posted : 14/07/2009 9:56 am
i use the king of shaves blue one as well. you get a big of clogging but nothing detrimental. with a mach 3, which clears pretty well.
Posted : 14/07/2009 9:57 am
Those electric multi blade jobbies don't seem to clog
As for a lube? - just normal soap for me
Posted : 14/07/2009 9:59 am
King of Shaves for me too (blue or green ones) - on its own, without any other foam/gel/etc - I've stopped getting any shaving rash since doing that.
Posted : 14/07/2009 10:02 am
Might sound daft but have you tried a good old fashioned shaving bowl and brush?
I've used oils, shaving foam/gel etc but nothing works for me as well as a bowl and brush.
Those new King of Shave razors are pretty good though.
I used to be a KoS adherent, I've started using olive oil instead and it's every bit as good.
Posted : 14/07/2009 10:08 am
I've tried pretty much everything, including old fashioned soap...thing is I don't shave daily so the longer stubble clogs more easily...KOS was mince also.
Oh well will try some shaving soap or gel...
Posted : 14/07/2009 10:18 am
I'd like to dry bum cynic-al.
Posted : 14/07/2009 10:20 am
 Olly
finishline wet lube.
GT85 stings like a mother...
Posted : 14/07/2009 10:31 am
 -m-
I've never really got on with shaving oils - always used to clog and still result in skin irritation.
There are a few different gels / creams that work OK for me, but KoS gel (in a squirty tube) tends to be the best price/availability compromise.
I think it's a case of trying different things and finding something that works for you.
Posted : 14/07/2009 10:32 am
i started using soap (and brush) a month or so back. nothing fancy, just what they had in boots. better shave than any of the foams and gels i've tried recently (after noxzema menthol got hard to get).
Posted : 14/07/2009 10:36 am
The Sanity Assassin - Member
Again? I haven't recovered from teh last time 🙁
Posted : 14/07/2009 10:37 am
If you're having that much trouble, is your technique right? Sounds silly I know but a mate of mine had a revelation when I told him to make sure that he never shaved 'against the grain' of his stubble and hadn't had shaving rash since. If that doesn't shave close enough then your blade's not sharp enough.
Posted : 14/07/2009 10:39 am
I bought a shaving soap dish and a handfull of blocks of glycerin soap (shaped to fit said bowl) from the soap factory shop in ashby (its name escapes me) for a fiver, kicks any other cream/foam ive tried into touch.
It also does CK anti-perperant sticks £20 in the shop, 3 for £5 with the label blacked out!
Have you tried old skool safety razors? No cloging problems there!
Posted : 14/07/2009 10:42 am
What olly said. GT85's got far to many solvents in to be useful for shaving, whereas Finishline wet lube clings to your face and wets the blades far better giving a really clean shave.
Some women do prefer the smell of GT85, so you might have to suffer the stinging and slightly rougher shave to keep em happy.
Posted : 14/07/2009 10:43 am
Haven't shaved for 6 months, but I was just using olive oil before that.
Posted : 14/07/2009 11:41 am
