How do you set yours up for indoor work.? Are there any setting within the 800 specifically for this.?
Posted : 22/11/2012 5:16 pm
as long as you have the cadence speed sensor it'll ask you if you want to run it with gps off when it can't get a fix.
Posted : 22/11/2012 5:18 pm
What he said. Or if it tries to get a GPS fix and almost manages then you can go into the menu and turn the GPS off.
Posted : 22/11/2012 5:21 pm
menu > gps status > off
should turn the GPS off, then speed sensor overrules it.
i've got a 500 i assume the 800 is similar?
Posted : 22/11/2012 5:27 pm
