I have some Deore LX M570 hubbed wheels that I'd like to service before I use them again. Can someone link me to a guide please?
the Park Tools website is pretty good for stuff like this
they're pretty straight forward, have you serviced a cup & cone hub before? If so, they're all pretty much the same
no have done hope before.
You'll need a set of cone spanners, grease, new bearings & cones ideally, plenty of rag & it's easy.
Disassemble from the non-drive side too, as you won't be able to do up the lock nut on the drive side when the axel is fitted.
Follow Pete's guide from here
http://www.mountainbikerides.co.uk/fettling/shimano_hub.htm
as it's the same on your LX hubs. Bearing sizes aren't the same front & rear though
*edit* the only thing I'd do differently is to remove the disc first if you have them, to prevent the risk of getting any grease on them
thanks buddy thats great
