Servicing marzocchi...
[Closed] Servicing marzocchi all mountain 1?
[#1718780]
last night i got some of the above forks which are the 2007 model he said they need a good service and some new seals i have had a quick search but carnt get any good advice just wounded if anyone can help
thanks luke
Posted : 18/06/2010 8:33 pm
take them to bits, pour in new 7.5wt oil, slather the internals with grease, put back together.
simples.
Posted : 18/06/2010 8:54 pm
yeah i had some 06's and they were easy enough to do - dead simple. just let the air out then dismantle and rebuild in the order you take em apart
Posted : 18/06/2010 8:55 pm
I don't know that particular fork but I have taken a few different zocchis apart.
I'd be very suprised if they need grease in them- usually zocchis are open bath with a large oil volume.
Easy enough to change the oil usually which is all that is needed but I don't have a service guide for that fork
Posted : 18/06/2010 9:00 pm
thanks alot do you no the best place to get the seals from?
Posted : 18/06/2010 9:22 pm
why do you want to change the seals? Are they leaking? if not leave them alone
Posted : 18/06/2010 9:31 pm
the guy who give me them said they need some
Posted : 18/06/2010 10:33 pm
If they're 2007 model, they'll be the AM1 SL which has a TST cartridge damper that'll need bleeing, and an air spring assembly with PAR bottom out control.
You can get service docs from www.windwave.co.uk go to the tech info section/marzocchi tech/fork service docs.
You can download a PDF with the instructions and photos.
You might need to find the TST bleed instructions in a different section to get that set up right.
Here's the Exloded diagram you won't find there.
HTH.
Posted : 18/06/2010 10:51 pm
Drop me a line about them, there is a cunning piece of string that fails in them, can be replaced though.
Posted : 17/08/2010 9:58 am
Hi Boobs
I have the 2007 AM1 SL - however I hear you can't get parts for them anymore? The travel has reduced to 120mm and my local bike shop can't help. What can you suggest please?
Richard
Posted : 05/02/2011 5:13 pm
Richard, I've got the same forks and had the same problem. You are right in that you can't get spares, see [url= http://www.singletrackworld.com/forum/topic/marzocchi-limited-support-for-forks ]this thread[/url] for details. To summarise it, contact Windwave and speak to Shaun. He can effect a fix that will return your forks to their former glory.
Posted : 05/02/2011 11:52 pm
