Seriously P'ee...
[Closed] Seriously P'eed off with my new Stan's 355 rims
Careful you don't fall off that high horse Will 🙂
My experiences are my own, perhaps I'm better at fitting tyres than you, perhaps I've not come across any of these tight Bonty tyres! I must say I've struggled with a set on some Race X Lite rims with Bonty's own rim strip, but never on Stan's rims of any flavour.
I've used the full range of Schwalbe tyres for about 3 years without a single notable flat, a couple when I've gone back to the bike and it's been flat. That's good enough for me! They're also not expensive when bought from Germany.
Conversely I know of at least one person off the top of my head who's destroyed a whole raft of Maxxis tyres when running them tubeless. Guess it depends how/where you ride!
Posted : 11/02/2010 3:08 pm
I was giving my best STW style response with no consideration that my opinion/experiences could not be true of every situation 😆
Posted : 11/02/2010 3:10 pm
Can't argue with that, it was a true STW response!
I gave up running non-ust tyres tubeless when I was riding along a fireroad and my Racing Ralph tore itself in two almost. I got mine from Germany also but they're all 'expensive' when you damage it beyond repair without much use out of it. Since then they're gone up in price, even the cheap sources as far as I am aware.
The Maxxis tyres I've had have been LUST, not tried them in non-ust variety.
Quite confident that my tyre fitting skills are up to the job but I've still had problems with a couple of Bonty ones. Problems that I've not had with other Bonty tyres. My point was that I reckon it is perfectly possible that the OP has a tight set rather than writing him off as some tyre fitting numpty. I should find another forum though really as that sort of balanced opinion is a bit unusual here!!
Posted : 11/02/2010 3:14 pm
Haha! Well I thought, in this situation, my more 'Communist' approach was better than a liberal suggestion that he may indeed have stumbled upon some tight tyres.
You being oop north tends to mean rockier terrain I guess, not much of that down here! I probably wouldn't use them so much if I lived somewhere like that, although I've still never had any problems at Afan/CyB etc, must be my mince-tastic style!
Posted : 11/02/2010 3:17 pm
Well I had never ripped or damaged a tyre until I left the South. Things just kept breaking after then, not just tyres either. There is a long list, of mainly weight weenie parts that broke including 4 Spark shocks, a bent set of Cobalt cranks (at Laggan noless), a Tune hub/freehub, Pace RC39 forks and lots more. So I've left all that weight weenie stuff behind, tyres included.
Posted : 11/02/2010 3:21 pm
Gravity's stronger further north, so you land harder. Fact.*
*may not be true.
Posted : 11/02/2010 3:22 pm
Fit one of these.
With one of these in it.
Then come back and tell me it's hard to change a pushbike tyre. 🙄 😉
Posted : 11/02/2010 5:52 pm
Stu your on fire 🙂
Sounds like making a very simple job difficult then blaming the equipment to me
Simple Stans 355's
3M mylar tape off ebay £5 for about 30 metres
Stans valve either type will do
Tyre on
Sealant in
Pump up
Shake rattle and roll
Leave on sides for a bit
Turn over
Then go for a ride
Bingo
Thats the SSS way to perfect tubeless every time
Posted : 11/02/2010 7:08 pm
 br
I use to have these in my m/c tyres..., was it a job
[url= ]Security bolt[/url]
Posted : 11/02/2010 7:56 pm
b r - Member
Security bolt
No need to use them in the front and only need one rear one when using a mousse. 😉
Posted : 11/02/2010 7:59 pm
Managed to get the tyre off, put it on the radiator to warm up, fixed the pinch flat, tyre went on a little easier this time round being warm.
I'm going to get the bits to go tubeless tomorrow, no way on earth could a tube be fixed out on a ride as it is.
Posted : 11/02/2010 8:49 pm
I had exactly the same problem with Flow Rims on Pro3s - My advise is to send them back.
I sent them back after spending an entire morning trying to get them on without success.
Sent them back for EX500s which I were easier to mount a tyre on.
To those ignorant ****s saying "why use tubes with tubeless rims", why post such a stupid bloody question FFS..But here's the answer anyway.
STANS ARE TUBLESS 'READY', NOT TUBELESS 'ONLY'.
Posted : 11/02/2010 9:23 pm
Touched a nerve there oops !
Funny that I am sure the trading name is quite heavily based around the theme 'NO TUBES'
not only in case of emergency' remove tubes' sorry to be so ignorant !
Posted : 12/02/2010 12:34 am
Got my new wheel yesterday with Stan's Flows, tried last night to put on a Bonty ACX as a test. Half an hour of swearing and grunting and a broken tyre lever later, but I did it! Boy was it tough. It's true that you have to get the bead down the middle channel, but it won't stay there easily. Took an age to then remove, I agree with the OP that it would be a farce to do at the trail side.
Going to set it up tubeless tonight. One question - if I try and fit tyre with Stan's fluid in it, it's going to go everywhere during the tyre-fitting wrestling match. Can I just pour it in through the valve instead, or will the world end? Or is that what the removable core is for? Stan's videos always show him putting the fluid in (ooo-err missus) into the tyre.
Posted : 12/02/2010 9:23 am
Indeed you can use the removeable core
You will get more air in for popping the tyre up on to the bead also
And only pour the fluid in just before you fit the final part of the tyre then turn 180 degress to keep the fluid in the beaded section of the tyre not all over the wheel tyre and yourself (Like i did the first time)
Posted : 12/02/2010 10:04 am
Built up a Flow rimmed wheel last night and popped a Kenda Blue Groove onto it by hand. Wasn't really any more difficult than any other rims I've had to be honest. Perhaps a little bit tight but nothing major. One thing I did notice though is that it was more difficult to get the tyre seated nicely (admittedly, with a tube) all the way round. There were bits of the sidewall that were sitting too far down in the rim which I usually solve on other rims by inflating to about 15-20psi then grabbing and pulling the tyre by hand. Pumping them up really heard to see if they would pop into place didn't seem to work either.
Will order some valves, tape and sealant next week but wanted to get them up and running with tubes ready for riding this weekend. I predict the beads will pop into place easier with no tubes.
Posted : 12/02/2010 10:16 am
You're joking?
You swapped for some other, significantly heavier rims, just because you couldn't fit tyres?
Of course you can run tubes, but it defeats half the point of using Stan's NoTubes rims!
Posted : 12/02/2010 10:26 am
[b]KingOfSweden[/b] Good tip on the Mylar Tape, Cheers
I nearly order some Stans yesterday
Just ordered 5 rolls off of ebay for £7.50 inc P&P 😯
Stans tape seems like a 'charge it because we can' sort of deal 🙄
same as the bloody over priced Valves £6.50 for a Valve I can get a whole tube for next to bugger all more than that
Posted : 12/02/2010 10:57 am
How many tubes do you think get made? How many tubeless valves?
Posted : 12/02/2010 11:59 am
[thread hijack] sorry
Aracer. Do you still want to sell that Speedneedle saddle?
Posted : 12/02/2010 12:24 pm
It's not as simple as that. There's no proper competition.
Mavic et al are no doubt fuming at the fact I use valves from old inner tubes 😡
Posted : 12/02/2010 12:28 pm
It is just as simple as that. Do you not realise how much more expensive it is running a supply chain for smaller volumes? Do you think there's no competition because nobody's interested in making the huge profits you appear to think there are in tubeless valves?
@ JamesP - yes, had forgotten I'd mentioned I'd got one. Should point out it's not in brand new condition - there's a bit of a wall scuff. Will e-mail piccies when I can get at my personal e-mail.
Posted : 12/02/2010 1:18 pm
Aracer - no worries, as and when you get a chance 🙂 Email address is in profile.
Posted : 12/02/2010 1:22 pm
No worries 🙂
Posted : 12/02/2010 1:28 pm
willsimmons - Member
Typical STW response to plea for help on this thread. The OP 'must' be doing it wrong because I/my mate/etc has done this blah blah.
So you think you know best 'cos you've worked in a shop for 10 years? I bet you've still got poor tyre fitting technique - not that it matters when you're sat on your arse eating pies and moaning at the computer screen. Learn to fit tyres and MTFU southerner. Now that'd be a typical STW response 😆
Posted : 12/02/2010 1:43 pm
 gamo
What width is this mylar tape? all looks too wide.
Seller ID?
Posted : 12/02/2010 2:05 pm
njee20 -
What so you're saying that 20gms a wheel is a significant weight increase...LOL
Posted : 13/02/2010 3:20 pm
I've got 355 rims. Various tyres have been fitted with no problems until I tried a Nevegal UST. Brought back memories of my enduro days(rim lock included} lots of sweating and swearing.....and then it was too wide for the back of the 575.
I use the yellow tape method. Works a treat.
Posted : 13/02/2010 4:59 pm
Yes! Got the ACX on the second time with the Stan's sealant almost without effort. It seems to go on much easier the second time, unless my technique somehow miraculously improved.
Felt so chuffed I took my newly-rebuilt ss out for a long ride.
Posted : 14/02/2010 12:14 pm
I had to install 3 of the tyre security bolts in the rear wheel of my old Honda CR 500 MX bike. I was glad to see the back of it! I know nothing about stan rims though. I just use Mavic rims and a tube!
Posted : 14/02/2010 1:01 pm
Been running tubeless 2 years now, have both Pro 2 819 combo and Pro 3 355 combo, some tyres are tighter than others its that simple. Would never go back to tubes, have had one or 2 mares but mainly due to me trying to get a bit more life out of a previously damaged tyre.
Oh and I run Conti Race kings non-tubeless ones, panaracer fire xc ust, maxxis crossmarks LUST, panaracer Trailraker UST on 819s with NO sealant and no problems ever, Panaracer Trail blasters (these were tight!). Have had one bad experience with tubed Schwalbe NN on a demo Giant Anthem X1, some people swear by them some about them. I may give them another chance as my Fire XC are in shreds.
Posted : 14/02/2010 1:59 pm
Page 2 / 2
