Serious helmet ques...
[Closed] Serious helmet question
[#7260238]
I just replaced my 3 year old POC Trabec with another one, albeit a Race.
The rear retention device has broken and to be fair I've dropped the helmet onto the ground a couple of times recently from the boot of my car so it was time!
The new one arrived today but a sticker inside the helmet caught my eye:
Year of manufacture 2011.
I checked my old POC (bought in July 2012) and it was made in 2012!
Shall I send it back on this basis?
I'm thinking so!
Posted : 11/08/2015 10:22 pm
is this a wind up?
Posted : 11/08/2015 10:27 pm
You're fine.
There is a school of thought that helmets only last five years or so but even that is blamed on a combination of UV exposure and sweat. A helmet that has been unused and boxed should be as good as new.
Posted : 11/08/2015 10:28 pm
I fear it might not be.
OP does the label say "best before"?
What do POC say?
Posted : 11/08/2015 10:29 pm
It's not a windup, given that half the retailers and all the manufacturers force the 'irrespective of use change every 4-5 years' spiel, I was surprised to receive such old stock.
Posted : 11/08/2015 10:31 pm
I prefer funny helmets.
Posted : 12/08/2015 7:14 am
I'd send that back on the grounds, although I am not sure on what grounds..
Posted : 12/08/2015 7:59 am
I think you'll be OK
Posted : 12/08/2015 8:01 am
It's that mysterious black hole that is helmets where there is lots of stuff banded around, but actually scientific evidence is thin on the ground.
Personally I'd be asking for another. No science behind it, but as helmet conpanies say, we shouldn't keep them that long. I doubt the place you bought it from kept the helmet for 5 yrs in a climate controlled environment
Posted : 12/08/2015 8:05 am
Polymers degrade due to exposure to UV and ozone.
Given how outrageously expensive POC helmets are, and the 5-year rule that is trotted out by retailers and manufacturers alike, I'd be sending it back.
If you bought it mail order you've got a 7 day cooling off period where you can return it "just because", you'd think they'd like to keep the sale by replacing it with a new one rather than refund your money.
Posted : 12/08/2015 8:21 am
Unless it was a bargain I'd send it back to if it were that old
Posted : 12/08/2015 8:23 am
I was gonna say, i think I'd be more annoyed by being sold something 4 years old without a hefty discount!
Posted : 12/08/2015 8:26 am
i'm pretty sure its 3 years...or at least thats what madison say about the giro helmets...but i would send it back due to it being such old stock and buy from elsewhere unless POC are still willing to honour any warranty the helmet may have.
Posted : 12/08/2015 9:32 am
How much ozone is there in the atmosphere?
Aren't helmets made of EPS not polymers?
Posted : 12/08/2015 9:38 am
I'd happily wear it if I needed a new lid urgently, but don't let anyone make you feel like a berk for sending it back.
Posted : 12/08/2015 9:45 am
Shelf life and use life tend to be different. Most climbing helmets manufacturers (eg Petzl) say a max shelf life (ie unused in the box) of 10 years, and a maximum use life (assuming reasonable handling, UV exposure etc) of 5 years. That tend to apply more to hard shell helmets as the plastics are more prone to ageing than expanded foam type contructions (IIRC). I've tested end-of-life hard shell helmets with a sledgehammer and the effects of age degradation are alarming!
It all varies from manufacturer to manufacturer though - there's no hard and fast rule other than "don't use beyond the manufacturer's recommendations". If you ask POC I'm pretty sure they'll tell you what they're max shelf life is. If it's 10 years then you'll be fine to get 5 years use out of it, if 5 years is their max use time.
Posted : 12/08/2015 9:49 am
its a natural component, and can be concentrated by pollution.
Expanded POLY Styrene is a polymer, made by joining styrene monomers
Posted : 12/08/2015 9:57 am
What colour is it?
[i]Done already?[/i]
Posted : 12/08/2015 10:01 am
 m360
Mine says 2002 in it 😯
If a helmet degrades to a point of been unsafe after 3-5 years sat on a shelf I'd be trusting a different helmet. Seriously. Th only reason they have a shelf life and then usage life is that CE markings dictate that they must.
Posted : 12/08/2015 10:02 am
Not directly applicable and we weren't being very scientific (!), but still interesting what age can do to plastics. Want to see the difference between a 5 yr old and a 10 yr old climbing helmet?
Posted : 12/08/2015 10:17 am
It's amazing what happens to two different helmets if you hit one harder than the other!
Posted : 12/08/2015 10:46 am
That sledgehammer was fully calibrated 😉
Posted : 12/08/2015 11:00 am
CTM do you have any evidence that there's enough ozone in the atmosphere to degrade EPS?
Or UV?
you've only stated it's possible so far, which says precisely nothing.
When I googled light degradation of EPS I found nothing.
Posted : 12/08/2015 6:15 pm
If helmets get brittle with age image the condition of your skull!!
Posted : 12/08/2015 6:21 pm
