Separating Shimano ...
[Closed] Separating Shimano shifter and brake...
[#10268785]
Mrs Beener has a 1x11 HT that has an XT shifter sat on the same mount as the XTR brake lever.
Am i correct in thinking this is i-spec? If so, how do i identify what sort it is? How do i separate them, so she can get both items in the position she wants them?
Posted : 09/10/2018 8:58 pm
Got a photo of it?
Posted : 09/10/2018 9:13 pm
Preferably featuring the part no of the brake lever. (Printed on master cylinder facing the handlebar).
Posted : 09/10/2018 9:19 pm
ok, i cant post a photo, but the brake is bl9000 and the shifter is 8000 series 11 sp xt.
does that help?
Posted : 09/10/2018 9:30 pm
ISpec ii then .
Posted : 09/10/2018 10:14 pm
Have a look at this with possible adjustment range:
https://bike.shimano.com/en-EU/technologies/component/details/i-spec-2.html
Posted : 09/10/2018 10:39 pm
If they are I spec 2 ( which seems likely from the series numbers) to run the separately you’ll need a spacer to replace the shifter in the brake lever clamp and a converter mount to mount an IPSec 2 lever to the bars like this  https://clee-cycles.co.uk/P51583/product
Posted : 09/10/2018 10:44 pm
I Spec II gives a fair bit of adjustment. Way more than the previous iterations.
Posted : 09/10/2018 10:47 pm
thanks all. i find the set-up nice to use but Mrs B with het Gollum like fingers seems to struggle to get a nice position.
I will check the links 🙂
Beener
Posted : 10/10/2018 9:40 am
